How to setup 2 in 1 out HE3D K200 to print 2 colours
Hello
I am new to 3d printing and have successful built my HE3D K200 and calibrated it to print one colour.
The is a 2 Filament in and 1 filament out, which allows you to print 2 colour objects or PVA Supports.
I would like some advice on how to configure the printer to do this in the Repetier Host program.
Can anybody help with this?
Many thanks
Guillaume
Many thanks
Guillaume
In host ou then load 2 Objects into one group and assign each the wanted extruder and slice with the multi color profile you set up.
As I am new to 3d printing and firmware configuration I'm not sure what T0 and T1 mean. I have attached the configuration.h file that came with the printer from the manufacturers.
I have changed the the settings to 2 extruders in the slicer, but this did not work, I also configured the settings to have a wipe tower, it printed the wipe tower and the part, but only in one colour, blue in this case, and not Red and Blue.
Perhaps you can point the correct part of the configuration.h file out to me in your own time, I guess you can just pinpoint the correct place rather than scrolling through the whole code.
Thanks again.
So first question is do you get that error or is the description of nozzle wrong? That is important since it makes configuration very different.
T0 is the gcode to select first extruder and T1 selects second extruder. Here https://reprap.org/wiki/G-code you find a list of printer g-codes to learn understanding what gets on.
i had the exactly problem as you described: heater/temperature sensor is defect.
its been an headache to make this thing word. is there any way you can help me with the configuracion? thank you in advance
