Deleting a batch of several G-CODE files quickly and easily?
We have several users & teams using the same Repetier server at our company.
Now there are hundreds of G-Code files uploaded to the server, and the only way I have found to delete these old redundant files, is to one-by-one press the red trash bin button and accept it individually deletion of each file.
Is there any faster option to select and delete a larger batch of files?
  • Sure. In gcodes ->action->Delete all files in group.
    If you connect with Repetier-Server Monitor you also have checkboxes to select gcodes and then you can delete marked gcodes.
  • Thanks a lot for your quick reply. I installed the Repetier-Server Monitor, it seems to be a great tool!
