Re analyse gcode on change
Hi!
I recently got myself a Prusa MK3s to replace my DIY printer. I discovered the @size commands to ignore the purge line, but not before I had uploaded a few gcodes. No problems, I thought, I'll edit the gcode on the server. But the server still shows the purge line. How do I get the server to re-analyse the code to take not the the @size commands?
Many thanks
So you will only get the benefits with new uploads you do containing the marker for renderings.
