Send print to multiple printers
Hello, I tried to find this topic but was unable. Is it possible to use Repetier Monitor to send a print to multiple printers or a group of printers without having to manually start the same print on each printer? If not, is there an API that would allow me to add this feature myself? Or has someone managed to do this already? Thank you!
https://www.repetier-server.com/using-simplify-3d-repetier-server/
describes how to print a gcode you have as file directly on a printer. You can use that to make a simple script uploading it to all printers the same time.
