After just switching to new version, RS doesn't start anymore. localhost:3344 is not responsive on Win10. Manually starting with admin righst also no luck. Back to 0.92.3 works well.
Can you tell more, since we can not reproduce this. On one pc we had it fail due to the fact that killing old server was delayed. Killing repetier-server instance and restarting installation manually then worked.
https://www.repetier-server.com/knowledgebase/autoupdate-update-fails/
Also when it fails what does happen when you start it manually as admin:
Start manually:
execute cmd.exe as administrator then run:
"C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.exe" /c "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml"
With the not stopped old server we got that accessing the server.log file failed as it was used by the still running instance.
Thank you I works properly now. (Sorry for late reply)
