Repetier-server won't load anymore - corrupted sd card
Hi, seems that something is wrong during boot process. I use it without any problem for a long time, then a day I came back to my home and server was down... unable to restart. Pi seems ok, replaced power supply, tested sd card in another Pi and same issue. I can open sd through windows so seems live. I know the most easy way is rebuild the sd card but i need to recover some projects already saved into the card. Where is stored? Is tit possible? There is a way to fix bootloader?
Thank you for your help.
If you can recover that create a new image and replace the same folder with your backup data. Only thing is if that folder has also a filesystem corruption some parts might not work. But as long as configs and databases are in tact there should be no big problems.
