93.1 update doesn't load on windows
in Bug Reports
Run the update to 0.93.1 and the server will not startup. Reinstall the 92.3 version and everything works
In that case please try starting it manually to see where it fails in your case.
Start manually:
execute cmd.exe as administrator then run:
"C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.exe" /c "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml"
First I tried the server 93.1 after the installation the server did not start, server 92.3 installed and running.
By web interface update to 93.1 after successful update the server does not start again.
Even starting the server by hand does not work.
Which windows version are you using? I have a current windows 10 as test system.
https://www.repetier-server.com/knowledgebase/autoupdate-update-fails/
I updated the version via the web interface without an error message. There was also no printer set up.
About the command:
"C: \ Program Files (x86) \ Repetier-Server \ bin \ RepetierServer.exe" / c "C: \ Program Files (x86) \ Repetier-Server \ bin \ RepetierServer.xml"
Since it works for me and you are the only one complaining so far is sounds like a local problem.
