System.UnauthorizedAccessException: Access to the path "/home/steve/.mono/registry/CurrentUser/softw
in Linux
I am getting the following error when i try to run repetierHost after i have updated to ubuntu 19.10.
subsequently i do not see my 2 printer in the list under connect.
System.UnauthorizedAccessException: Access to the path "/home/steve/.mono/registry/CurrentUser/software/repetier/values.xml" is denied.
Also, (separate issue) even before the update. I needed to run repetierHost as sudo or the software would only be working for a second or 2 before it was gone.
whiteNORTH
