CNC Mode Freezing up
Anyone else have a problem where when using cnc mode to engrave the cutter will keep going but the axis movements stop and it just sits and spins a hole in the material and is completely unresponsive leaving nothing to do but a e-stop?
  • Does the server stop sending commands? Do they get rejected by an error? Please check console and enable also ack/commands to see everything that is going on.
  • this was the last thing before it stopped:
    ok 678
    N684 M117 ETE 33m 58s*73
    ok 679
    N685 G1 X84.033 Y34.686 F600*113
    And then it just stops moving and the cutter keeps spinning, and i have to do a E-stop on it
  • That is bad. Looks like usb serial stack hangs so server keeps it open but gets no more responses. Known problem but it is outside of the server. Either linux or printer converter are stuck on communication here.
    Is that on a raspberry pi? Then make sure power supply is good and that it is NOT just a usb charger. Chargers are not stable enough to run raspberrys stable in most cases.
    Do you have a lcd display for firmware? Normally on these hangs firmware lcd is still responsive since it is no firmware hang but a serial com hang.
  • It is a ATmega2560, connected to my pc and the printer has a 250w supply of its own. Yes i have a display on it
  • It appears to be caused by the reporting of the temperature from the printer to the pc, is there a way to turn off the temp reporting?
  • Not really. Server activates autoreporting at connection when it sees this or queries every second. Should not be a problem. Maybe you just think it as it is a frequent thing happening. Anyhow if you have no heaters in firmware Commands::printTempertures in Commands.cpp. If you strip everything it it firmware will never report any temperatures.
    If it hangs test with lcd if you still can e.g. move. Then it is clear firmware is running and serial stack is down somehow.
  • yes is still moves and responds by the display controls just not from the pc
  • Also using the setting under printer settings in repetier host i was able to turn off temperature checking and it stopped showing in the log window and i was able to get the gcode to make it all the way through without error, but i have not been able to get it to turn off again
  • " but i have not been able to get it to turn off again" assuming you mean on, what was the problem? Did it stop responding with firmware then?
    BTW, how does your temperature response look like and what did you define in extruder as sensor? As I see it it would read a temperature with whatever you defined for extruder and output it also you do not need it. Something FDM printer do all the time without problem. So strange. Did you set it to fake thermistor to get always same temperature or anything dynamic that can lead to problems?
  • When i use the cnc I switch carriages and the hotend temp sensor is no longer connected.
    my temp output is: T:-50.88 /0 B:24.03 /0 B@:0 @:0
    Here is what i have:
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN 11
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 50
    #define YAXIS_STEPS_PER_MM 50
    #define ZAXIS_STEPS_PER_MM 200
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 47
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN 5
    #define EXT0_JAM_PIN 57
    #define EXT0_JAM_PULLUP 1
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 2
    #define RETRACTION_LONG_LENGTH 2
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  10
    #define JAM_METHOD 3
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 10
    #define SKIP_M109_IF_WITHIN 5
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 5
    #define HEATED_BED_HEATER_PIN 8
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 15
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 1
    #define LASER_PIN 4
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 1
    #define LASER_PWM_MAX 255
    #define LASER_WATT 5
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 1
    #define CNC_WAIT_ON_ENABLE 500
    #define CNC_WAIT_ON_DISABLE 1000
    #define CNC_ENABLE_PIN 4
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 12000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_Z2_MINMAX_INVERTING true
    #define MINMAX_HARDWARE_ENDSTOP_Z2 true
    #define ENDSTOP_Y_MAX_INVERTING true
    #define ENDSTOP_Z_MAX_INVERTING true
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN 15
    #define DOOR_PIN 2
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 1
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 265
    #define Y_MAX_LENGTH 235
    #define Z_MAX_LENGTH 248
    #define X_MIN_POS -27
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 3
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 8
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define FEATURE_TWO_ZSTEPPER 1
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z4_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 2
    #define Z_PROBE_PIN 6
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET -3
    #define Z_PROBE_Y_OFFSET -38
    #define Z_PROBE_SPEED 0.125
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 0.02
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 0.3
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 -8
    #define Z_PROBE_Y1 43
    #define Z_PROBE_X2 188
    #define Z_PROBE_Y2 46
    #define Z_PROBE_X3 92
    #define Z_PROBE_Y3 194
    #define BED_LEVELING_METHOD 0
    #define BED_LEVELING_GRID_SIZE 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Mystique"
    #define UI_PRINTER_COMPANY "Q-Branch"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 1
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_START_SCREEN_DELAY 4000
    #define UI_SET_MIN_HEATED_BED_TEMP  60
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • Ok, the temperature report is ok without sensor. Don't think that will crash communication.
    Still think it is some problem is serial communication queue from all I read. You can try an active hub between pc and printer - maybe it improves. Also make sure usb cable is not too long and shielded. Might work or not.
  • Changing usb ports fixed it
  • Great. So port caused usb crash and the other does not have that problem:-)
