Save Console/terminal options
Please had one option tom save console/terminal options on Repetier-server. Every time I access terminal I must change the settings for ACK and commands.
  • That is generally a bad idea. As soon as you enable that server will send all the log events even if you do not see them. Means in 99% of the cases you would just add load and traffic to the client to have it enabled by default. Most users never use console or only on errors or special problems. So not sending all that data by default makes sense.
  • I understand that. It's a sensate option. But I think it would be better to have a button to save this settings or discard, perhaps with a advice for overloading traffic.
