First Layer Great...the Rest not..
The speed for my first layer is perfect. Then things speed for the other layers and the filament is not extruding at the pace of speed of the machine.
What is the name and the location of what can adjust these 2 issues... Speed of Filament and the Speed of the Program?
  • In slicer configuration you set the speeds.
  • Not sure where I would speed up the flow of the Extruding Motor.
    I see Slicer Configuration. Then what do I adjust? Support Material Interface? It's at 100...would I go something like 140?
  • Did you calibrate your extruder steps per mm?
    In slicer you can change flow multiplier in filament settings to adjust to different filaments.
