Argument out of Range
Im new to 3D printing. I have bought a Tronxy P802. I was setting up Repetier Server after Repetier Host. When I uploaded a test G-code, the printer stopped. - This message came up on the Repetier Server - System. ArgumentOutOfRangeException: Value of '200' is not a valid for 'Value'. 'Value; should be between maximum and minimum.
Also - Exception during socket read: Object not set to an instance of an object.
Can anyone help me?
THanks
  • Are you using latest host version 2.1.6?
    These sound like communications errors of host with server, especially if you see them in host log.
    If you are on latest version is that repeatable and which steps need to be done to create the error?
  • Thank you, the update sorted it out
