Printer Monitor
Is it possible to run strictly the Repetier Server Monitor app on says something like a Rasp Pi?
The desktop apps are great, it'd be nice to have a simple monitor on a Pi with 5" display (HDMI) for example, where all the printers show and their state/status can be monitored over the network.
Mel
  • The Repetier-Server Monitor was written with a bigger monitor in mind. 1024x768 is the minimum I think. Also there are no binaries for linux arm available, only 64 intel linux. So at the moment the answer is no. Maybe in future we will add arm versions for it if electron supports the platform.
  • edited October 2019
    Thanks for the quick reply. I'd tried a few of the 64 bit Rasp PI OS's with the Appimage to see if anything would work and nope. So good to know I can toss the pi back in the parts bin.
    Currently I use a print monitor that runs on an ESP8266 with either an OLED or TFT but it can only show one printer instance, whereas with your Printer Monitor it's possible to see all the printers. No control on my monitor of course, strictly for status of the printers.
    A tech question though. How often does Repetier Server Monitor query Repetier Server Pro for information? That would be a good thing to know so I don't overload the Server with info requests...
    For Repetier Server Pro running on the Pi, I have to start the PRUSA i3 MK3S first, then the server. Other way around the PRUSA never finishes starting up. Not sure what Server Pro is doing but during boot up it will cause the PRUSA to reboot 3 or 4 times before the info screen on the PRUSA shows up.
    For the deltas I have connected, I see a reboot on the deltas exactly once and its done.
    Mel
  • The monitor has a new system that only gets changes from server to reduce traffic and modifications required to a minimum. But of course more printers is more data and modifications. Frequency i do not know at the moment. I think maximum 10 hz if no questions get send. On every response the events get also send. No problem for a regular PC. A pi - I can not say. A pi 4 is also pretty fast so might work up to a number of printers.
    I have my prusa on the internal serial connector so I can not reset. But never noted this behaviour. Will retest with external serial. Server restarts connect if it does not see the "start" response or any useful communication data after a few seconds.
  • As far as I'm aware, with the internal serial connector it works completely different than the USB one. I was going to stick a Pi Zero in my PRUSA but opted for the Pi 4 because it will run all three of my printers via USB.
    I really like the Monitor concept and would like a simple monitor that basically shows what we see on the default Monitor page (summary of the printers). Maybe it'll be my winter project...:-)
    The only thing I'd add to the current Printer Monitor is the ability to reboot or shut the server down from the summary display.
    Mel
  • Ok tested enabling prusa on usb after server has started. That was no problem. One reset. I had "Port is visible even if firmware is not running" activated, which I developed especially for Prusa where port is visible also printer and firmware are not working. That feature had a problem in the past, but in 0.92.3 it is working fine. Not sure when i fixed it.
    Choosing the pi 4 over pi zero is a good decision. Pi 0 works but is soo slow compared to pi 4.
    For the monitor there is a quite simple solution:
    https://www.repetier-server.com/customizing-printer-frontend/
    You can use our sources and write just a page that accesses all printers data. That solution polls all data of the printers on your pi 4 so all you need to do is write an extra page with overview. Main problem for us is to find a solution working from 3 inch to 7" or even 10" displays. Maybe at some time we also add an info screen for all printers on the device at least for bigger displays. Still have some plans to improve the touch gui.
    Adding a context menu to printer overview in monitor is also something we are thinking about.
  • I had the Port Visible unchecked so I've checked that and will retry it. I remember unchecking it with firmware 3.8.0 on the MK3S because of some issue at the time which may or may not have been related. I'm using 3.8.1 now.
    The printer front end link looks interesting but geared more towards the Raspberry PI than the ESP8266 or ESP32's that get the same job done at 1/10th the hassle and cost for me. Rasp Pi doesn't have a decent C++ IDE environment so I favour the ESP's for doing task specific stuff like a simple printer monitor. Hence I plan to use the API to query and a TFT to display.
    I'm use SPI to communicate with an 2.8" TFT for the monitor, small and unobtrusive. I know those work fine together so it'll just be formatting for the display and the API to get the data from the server. Like I said, winter project...:-)
    For controlling and sending print jobs to both my deltas and my PRUSA at the same time, Repetier Server Pro is the best investment I ever made. The others I've tried like Octo and Astro will cause a delta to stutter badly with any curved prints at 45+mm/s speeds and will always take longer to print than the same SD card file, they do work with the PRUSA. Repetier Server on the other hand just works with all three. Excellent software.
  • Follow up for the reboots, checking the port active fixes the reboots and stalls. Thanks!
    Mel
