Unable to center print
The printer head goes 45 degrees from the start point to the other side of the bed and will not stop unless I hit the kill button.  Printer will stop at edge of bed in manual mode.  Seems to do with the slicing software. Same results with Slic3r and CuraEngine.  Any ideas?
  • Wrong settings. Check bed dimension and location set in host and compare with coordinate system set in firmware.
