Did you delete so much or is it from an older marlin.xml derived?
There is no eeprom type mk4due. It is either marlin or repetier if you can update it with M205/M206. If I remember right at least old marlin kimbra did use that.
As far as I know m4due was derived somehow from marlin so I wonder you removed M108 which I see in mk4due gcode list and I also see that it supports emergency parser.
