dropping printer connections
Hello, we have 3 Prusa i3 mk3 running on RS in our university printing lab. One issue we have been having is that RS will seem to randomly drop connections with the printers. Upon restarting the server on the computer, the connections will be reestablished. Unfortunately, since the common user doesn't have privileges to restart the server, they have to restart the entire computer. This is very time consuming, and can interrupt any ongoing prints.
Can you point us in the direction of some troubleshooting for these dropped connections?
dmesg
to see if you have problems with undervoltage. Not all undervoltages cause usb connection being dropped. If you know when it happened check /var/log/syslog - it will be noted there.
Instead of restarting server it should also work to unplug usb and unpower matching prusa and reconnect. That would force both sides to reinit the communication chips so if the problem is the prusa communication or if it is the linux side would not matter. Eventually just unplugging and replugging usb would also do the trick. Hard to say without knowing what goes on.
Hope this helps otherwise please describe more detailed if one or all are affected and which of the above works, which hardware is used...
We have three printers, all the Prusa i3 mk3 model.
Printer 1 has rarely dropped the server connection.
Printer 2 drops the connection more regularly.
I just tried the following procedure with Printer 2:
Disconnected USB.
Power-cycled printer.
Reconnected USB.
Temperature readout was displayed on dashboard.
Attempted to print.
Printer did not respond - no preheating - just sat idle.
Issued M117 command - no response.
Issued M104 command - no response.
Repeated the above sequence several times.
Restarted the computer.
Sent a print job to the same printer.
Job printed normally.
You might try a different usb cable. Often also a source of problems especially if it is a long usb cable. Especially 5m cables are not really specified I think also they often work.
