How to use extcommands?
My /var/lib/Repetier-Server/database/extcommands.xml looks exactly like this:
<config>
<command>
<name>extcmd test</name>
<execute>date | tee /tmp/test.txt</execute>
<confirm>Execute Test?</confirm>
<!-- Define if command should show up in local printer interface, default true.-->
<local>true</local>
<!-- Define if command should show up in remote printer interface, default true.-->
<remote>true</remote>
<!-- Define if command should show up only for users with print permission, default true.-->
<print-permission>false</print-permission>
<!-- Define if command should show up only for users with add files permission, default false.-->
<add-permission>false</add-permission>
<!-- Define if command should show up only for users with del files permission, default false.-->
<del-permission>false</del-permission>
<!-- Define if command should show up only for users with configuration permission, default false.-->
<config-permission>true</config-permission>
</command>
</config>
The (demonstration) purpose is to write the output of the command date (current date and time of command execution) into the local file /tmp/test.txt.
I have restarted RepetierServer and found the new menu entry extcmd test as expected. When I activate that menu item and accept the confirmation dialog, nothing is written to the disk. I see no /tmp/test.txt while the /tmp folder is writable to everyone (perms: 077/rwx,rwx,rwx).
How to perform the desired action?
I am using Petetier-Server Pro 0.92.3.
PS: The later goal is to write a random token to disk, and trigger an external web service afterwards. I need to write something to the local disk and place a web call (e.g. using wget).
#!/bin/bash
With permission rx for everyone in /var/lib/Repetier-Server/scripts/
