connection problem between repetier and Cura 4.2.1
in CuraEngine
i am trying to connect these two, but always have connection problem, tried IP, server connection, neither worked.
i put in IP and port number, it tells me the target machine fails to respond.
- 5353: Discovery
- 80: Printer control
- 8080: Camera feed
Not sure which would be used e.g. by cura or if they have a special ultimaker only solution. Would just try all 3 with your printers ip and see if one manages to connect. I guess 80 will be some web interface to control so I'd bet on 5353 also discovery might be anything.Where did you find port port 9066?
