Update 0.92.1 no screen to PI
I update my repetier server ( 0.75 to 0.92.1) by the web interface and the autoupdate  by computer,
it s ok in web page in computer , i have the printer, menu....
but in the screen of the PI i have a empty page ( grey page and just the print/manual control/setting menu) no acces to printer, control ....
Thanks.
  • 0.75 is quite old. So I guess your image is also old. Many has changed sind then especially we have a new touch screen interface with a new url, also the old should still work but did not test recently. Plus it might be that the old image is not using chromium but kweb as browser which does not support the required flex box css properties.
    The best solution would be to reinstall our current image or better wait for the next image coming in a few days with the new version. If you copy your content under /var/lib/Repetier-Server to the new image you will have all content and settings 1:1 like in the old version.
  • Hello,
    I have install the last PI sd image and all is ok .
    Thanks .
