How to export / save settings and files? (Raspberry)
Hey Guys,
I've tweaked around on my Repetier-Server to get a touchscreen to work.
Unfortunately I've somehow damaed the webinterface (nginx 502).
So I used another SD-card and did a fresh install. (The display works!)
But.... I lost all my records for previous prints and also some GCODES I only had remaining in repetier.
How can I export those two to the new installation?
Are the just some folders to be copied?
Regards,
Matthias
  • For linux you just need a 1:1 copy of /var/lib/Repetier-Server which contains all settings and data. Make sure server is stopped when you copy and start server after copy so server reads the new data.
  • Thanks! I'll try it when I'm back home!
