Error Unknown command M20 and M80 And active extruders 0
What should i do when i changed my extruder from the original prusa i3 reprap printer to this:
 https://www.amazon.com/Extruder-Printer-Filament-Extrusion-Aluminum/dp/B07P91BNMY
and when i try to connect it by repetier host it says like this
21:33:35.848 : Printer reset detected - initalizing
21:33:35.848 : start
21:33:35.848 : echo:Marlin 1.1.9
21:33:35.851 : echo: Last Updated: 2018-08-01 | Author: (none, default config)
21:33:35.852 : echo:Compiled: Jul 31 2019
21:33:35.855 : echo: Free Memory: 5628  PlannerBufferBytes: 1232
21:33:35.857 : echo:Hardcoded Default Settings Loaded
21:33:35.858 : echo:  G21    ; (mm)
21:33:35.859 : echo:Filament settings: Disabled
21:33:35.859 : echo:  M200 D3.00
21:33:35.860 : echo:  M200 D0
21:33:35.860 : echo:Steps per unit:
21:33:35.863 : echo:  M92 X80.00 Y80.00 Z4000.00 E500.00
21:33:35.865 : echo:Maximum feedrates (units/s):
21:33:35.866 : echo:  M203 X300.00 Y300.00 Z5.00 E25.00
21:33:35.867 : echo:Maximum Acceleration (units/s2):
21:33:35.869 : echo:  M201 X3000 Y3000 Z100 E10000
21:33:35.873 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
21:33:35.874 : echo:  M204 P3000.00 R3000.00 T3000.00
21:33:35.880 : echo:Advanced: Q<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>
21:33:35.882 : echo:  M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00
21:33:35.883 : echo:Home offset:
21:33:35.884 : echo:  M206 X0.00 Y0.00 Z0.00
21:33:35.885 : echo:PID settings:
21:33:35.887 : echo:  M301 P22.20 I1.08 D114.00
21:33:36.050 : N1 M110*34
21:33:36.050 : N2 M115*36
21:33:36.050 : N3 M105*36
21:33:36.050 : N4 M114*35
21:33:36.064 : N5 M111 S6*98
21:33:36.064 : N6 T0*60
21:33:36.064 : N7 M20*22
21:33:36.064 : N8 M80*19
21:33:36.064 : N9 M105*46
21:33:36.151 : FIRMWARE_NAME:Marlin 1.1.9 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:33:36.151 : N10 M220 S100*80
21:33:36.151 : Cap:SERIAL_XON_XOFF:0
21:33:36.152 : Cap:EEPROM:0
21:33:36.152 : Cap:VOLUMETRIC:1
21:33:36.154 : Cap:AUTOREPORT_TEMP:1
21:33:36.155 : Cap:PROGRESS:0
21:33:36.155 : Cap:PRINT_JOB:1
21:33:36.156 : Cap:AUTOLEVEL:0
21:33:36.156 : Cap:Z_PROBE:0
21:33:36.157 : Cap:LEVELING_DATA:0
21:33:36.158 : Cap:BUILD_PERCENT:0
21:33:36.159 : Cap:SOFTWARE_POWER:0
21:33:36.159 : Cap:TOGGLE_LIGHTS:0
21:33:36.160 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:33:36.161 : Cap:EMERGENCY_PARSER:0
21:33:36.163 : Cap:AUTOREPORT_SD_STATUS:0
21:33:36.165 : Cap:THERMAL_PROTECTION:1
21:33:36.165 : N11 M221 S100*80
21:33:36.173 : N12 M111 S6*84
21:33:36.174 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
21:33:36.174 : echo:DEBUG:INFO,ERRORS
21:33:36.175 : N13 T0*8
21:33:36.175 : N14 M155 S1*85
21:33:36.175 : echo:Active Extruder: 0
21:33:36.176 : echo:Unknown command: "M20"
21:33:36.179 : echo:Unknown command: "M80"
21:33:36.185 : echo:DEBUG:INFO,ERRORS
21:33:36.187 : echo:Active Extruder: 0
21:33:56.451 : N15 G1 Z1 F100*0
21:33:58.949 : N16 G28*36
21:34:00.798 : N17 M140 S55*99
21:34:01.056 : N18 M104 T0 S200*26
21:34:01.296 : N19 M106 P0 S255*29
21:34:01.856 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
21:34:22.147 : Error:Heating failed, system stopped! Heater_ID: 0
21:34:22.147 : Error:Printer halted. kill() called!
21:34:26.688 : N20 M999*24
21:34:26.688 : N1 M110*34
21:34:27.682 : N1 M110*34
  • The unknown commands are no problem. Server ignores them on further occurences.
    Problem is that heater in firmware fails and then firmware stops executing any commands. So once you solve the configuration it should work. But can‘t say how to reconfigure prusa firmware for new extruder.
  • well what should i do when the thermistor is a 100k and i cant figure out what should i change in the firmware because i am new to this whole firmware and 3d printing stuff, my 3d printers original extruder got jammed and i had to buy a new one and it has not worked after that
  • Don‘t know marlin good enough but that it shows at startup could mean there is temperature reading from beginning. Mean a broken wire, not connected to right pins, ...
