V2.0.5 Repetier host freezes
when I start repetier it stops and freezes up. I have to go to the tasked program and end the process there. Probably should reinstall.  Any ideas before I do anything
  • Upgrade to 2.1.6.
    At which state does it freeze?
    One thing you always can try is open regedit and rename HKCU/Software/repetier to an other name (there all settings are stored) and start. Then it recreates settings - just in case a setting is causing the freeze. If it is the case remember what you changed last before it started happening. You can copy old settings back and then remove these settings or just reconfigure printer. Slicer settings are stored in directories and will not be lost especially if you use same printer name.
