File name "dummy" when print directly with API
Hi guys,
Im working with API commands, and when i send a gcode with direct print command, the file is named "dummy". I have a problem with this because i use this field to compare with other info stored in a database.
I need that when i use direct print command, this use the original file name.
Any idea about how to preserve the original file name¿?
Thanks.
Regards.
Thanks.
Regards.
