No, but here a sample that makes a led blink and shuts down pi on button press
rs = RepetierServer()
local GPIO = periphery.GPIO
local loopCounter = 0
local blink = false
local blinkOn = true
local lastButton = true
local gpioBlink = nil
local gpioButton = nil
function setup()
print("lua setup called")
gpioBlink = GPIO(3, "out")
gpioButton = GPIO(2, "in")
print("lua setup finsihed")
end
function loop()
print("loop")
loopCounter = loopCounter + 1
if lastButton ~= gpioButton:read() then
lastButton = not lastButton
print("Button " .. tostring(lastButton))
if lastButton then
blinkOn = not blinkOn
os.execute("sudo /sbin/shutdown -h now")
end
end
if loopCounter >= 100 then
loopCounter = 0
if blinkOn then
blink = not blink
gpioBlink:write(blink)
print("Blink:" .. tostring(blink))
end
end
end
Also a snippet to send a gcode(M119) to all printers being active:
function sendM119()
pList = rs.printerList
for _,printer in pairs(pList) do
if printer.activated then
printer:injectManualCommand("M119")
end
end
end
Watch out with shutdown example - a small error there will shutdown pi as soon as server starts! Just copy the lua script to /var/lib/Repetier-Server/lua and restart server. Watch server.log as script errors and print commands get written there. So that is your main point in finding errors in scripts.
local blink = false
function setup()
end
function loop()
print("loop")
if lastButton then
end
end
loopCounter = 0
if blinkOn then
blink = not blink
end
end
end
