Server port number
Is there a way to change the port for a server from the default 3344 to another port number?
I'm installing multiple servers on my network and want to be able to access them from outside my local network.
I am using the direct install of the "Image V14 with Repetier-Server 0.91.2 for Raspberry Pi"
Thank you...
Thank you...
Second you can add a copy of repetier-server.xml in storage database and modify the port number. After restart that xml will override the original file.
