Extrusion stops with flow setting below 100%
in Bug Reports
Sometimes I need to change the flow parameter a little below 100%. That was no problem with previous versions of Repetier-Server. But with version 0.91.2 the extrusion immediately stops when I change the flow below 100% during the print.
I'm using Repetier-Server on a RaspberryPi 3.
I didn't change the firmware the last few years, I will take a look on that. My printer is a GermanReprap Protosv2.
