Prusa MK2.5 connected but not receiving data
Repetier Server 91.2, Prusa firmware 3.70 for the MK2.5. Server says there is a connection but I can not do the heating wizard - it just does nothing. Also if I try to send a gcode nothing will happen. I get multiple time out messages.
At least in MK3 you can select output port for marlin between usb port and internal serial header. If that is the same with 2.5 make sure it is selected to where you connected it.
Do you now have a version running and which one? Have you marked the post is always visible when unconnected flag in printer configuration? Is prusa selected to use the right serial (you can switch between usb and rpi internal connection).
