"repetier communication timeout reset send buffer block"
windows 10
repetier 2.1.3
printrbot simple pro (lastest firmware)
usb
just started giving me this error last week.
was only doing it after @pause.. i removed the next line that changed the temp and that fixed it for one print
printed sucessfuly last nite. turned off printer, left repetier open, changed nothing, errored out again this morning.
rebooted everybody and it seemed to work on a 1/3 scale of stl.. ..YET... half way thru a full scale ... errored out again!!!
  • Timeout happens normally on 2 occasions:
    1. Firmware hangs/takes long when not expected.
    2. Communication error caused the "ok" returned by firmware to be received as "o" or "k" or something other. So host does not know it can send next line and then it times out - assumes that exactly that happened and continues sending commands. But it continues the print after timeout seconds.
    WIthout seeing an unfiltered log around the problem part I can not say more.
  • Hi,
    Happens the same to me.
    I was printing iwth no problems. And now my prints just stops randomly. (now its in the first 10 minutes)
    Here is a log.. what can it be? it was working propperly..
    I deleted some lines of the:
    18:50:12.996 : ok T:205.3 /205.0 B:24.9 /-273.1 @:28
    because it was too long.
    18:35:52.150 : OpenGL version:4.6.0 NVIDIA 425.31
    18:35:52.150 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
    18:35:52.150 : OpenGL renderer:GeForce GTX 650/PCIe/SSE2
    18:35:52.150 : Using fast VBOs for rendering is possible
    18:36:04.291 : Printer reset detected - initalizing
    18:36:04.337 : start
    18:36:04.337 : echo: External Reset
    18:36:04.337 : Marlin 1.0.1 RRP
    18:36:04.337 : echo: Last Updated: 2014-07-05-Lankeda-i3 | Author: Sim Wang
    18:36:04.337 : echo: Free Memory: 11513  PlannerBufferBytes: 1232
    18:36:04.337 : echo:Stored settings retreived:
    18:36:04.337 : echo:Steps per unit:
    18:36:04.337 : echo:  M92 X100.000 Y100.000 Z2560.000 E100.000
    18:36:04.337 : echo:Maximum feedrates (mm/s):
    18:36:04.337 : echo:  M203 X300.000 Y300.000 Z3.000 E45.000
    18:36:04.337 : echo:Maximum Acceleration (mm/s2):
    18:36:04.447 : echo:  M201 X800 Y50 Z?start
    18:36:04.447 : echo: External Reset
    18:36:04.447 : Marlin 1.0.1 RRP
    18:36:04.447 : echo: Last Updated: 2014-07-05-Lankeda-i3 | Author: Sim Wang
    18:36:04.447 : echo: Free Memory: 11513  PlannerBufferBytes: 1232
    18:36:04.447 : echo:Stored settings retreived:
    18:36:04.447 : echo:Steps per unit:
    18:36:04.447 : echo:  M92 X100.000 Y100.000 Z2560.000 E100.000
    18:36:04.447 : echo:Maximum feedrates (mm/s):
    18:36:04.447 : echo:  M203 X300.000 Y300.000 Z3.000 E45.000
    18:36:04.462 : echo:Maximum Acceleration (mm/s2):
    18:36:04.462 : echo:  M201 X800 Y50 Z30 E250
    18:36:04.462 : echo:Acceleration: S=acceleration, T=retract acceleration
    18:36:04.462 : echo:  M204 S1000.000 T1000.000
    18:36:04.462 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s),  Z=maximum Z jerk (mm/s), K=advance_k
    18:36:04.462 : echo:  M205 S0.000 T0.000 B20000 X15.000 Z0.400 E15.000
    18:36:04.462 : echo:  M206 X0.000 Y0.000 Z0.000
    18:36:04.462 : echo:  M208 X210.000 Y210.000 Z160.000
    18:36:04.462 : echo:PID settings:
    18:36:04.462 : echo:   M301 P12.000 I2.200 D80.000 W125
    18:36:04.462 : echo:Thermistor settings: M304 Hh Bb Rr Tt, H0=Bed, H1..n=nozzle, b=thermistor beta value, r=series resistor, t=thermistor resistance as 25C
    18:36:04.462 : echo: M304 H0
    18:36:04.462 : B3960 R10000 T100000 M304 H1
    18:36:04.462 : FPU Enabled no
    18:36:04.541 : N1 M110*34
    18:36:04.541 : N2 M115*36
    18:36:04.541 : N3 M105*36
    18:36:04.541 : N4 M114*35
    18:36:04.541 : N5 M111 S6*98
    18:36:04.744 : transform correction not enabledecho:SD card ok
    18:36:04.744 : echo:enqueing "M23 auto0.g"
    18:36:04.744 : echo:enqueing "M24"
    18:36:04.744 : ok
    18:36:04.744 : open failed, File: auto0.g.
    18:36:04.744 : ok
    18:36:04.744 : ok
    18:36:04.759 : N6 T0*60
    18:36:04.759 : N7 M20*22
    18:36:04.759 : N8 M80*19
    18:36:04.759 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1
    18:36:04.759 : ok
    18:36:04.759 : N9 M105*46
    18:36:04.806 : ok T:155.1 /-273.1 B:24.5 /-273.1 @:0
    18:36:04.806 : N10 M20*32
    18:36:04.806 : X:0.000Y:0.000Z:0.000E:0.000 Count X:0.000Y:0.000Z:0.000
    18:36:04.806 : ok
    18:36:04.806 : ok
    18:36:04.806 : echo:Active Extruder: 0
    18:36:04.806 : N11 M220 S100*81
    18:36:05.791 : T:154.5 E:0 W:?
    18:36:40.457 : T:194.5 E:0 W:?
    18:36:41.492 : T:196.3 E:0 W:?
    18:36:42.545 : T:197.8 E:0 W:?
    18:36:43.579 : T:199.6 E:0 W:?
    18:36:44.595 : T:200.6 E:0 W:?
    18:36:44.876 : Communication timeout - reset send buffer block
    18:36:44.876 : N12 M221 S100*83
    18:36:44.876 : N13 M111 S6*85
    18:36:44.876 : N14 T0*15
    18:36:44.876 : N15 M105*19
    18:36:45.595 : T:201.6 E:0 W:?
    18:36:46.595 : T:202.7 E:0 W:?
    18:36:47.611 : T:203.2 E:0 W:4
    18:36:48.611 : T:204.1 E:0 W:3
    18:36:49.611 : T:204.2 E:0 W:2
    18:36:50.626 : T:204.8 E:0 W:1
    18:36:51.626 : T:205.0 E:0 W:0
    18:36:51.845 : ok
    18:36:51.845 : Begin file list
    18:36:51.861 : N16 G28 X0*108
    18:36:51.899 : AUTO0.GCO
    18:36:51.903 : End file list
    18:36:51.903 : ok
    18:36:51.903 : N17 M105*17
    18:36:51.903 : ok
    18:36:51.909 : ok T:204.9 /205.0 B:24.5 /-273.1 @:45
    18:36:51.909 : Begin file list
    18:36:51.909 : AUTO0.GCO
    18:36:51.909 : End file list
    18:36:51.909 : ok
    18:36:51.909 : ok
    18:36:51.909 : ok
    18:36:51.909 : ok
    18:36:51.909 : ok
    18:36:52.447 : ok
    18:36:52.462 : ok T:205.4 /205.0 B:24.4 /-273.1 @:39
    18:36:53.638 : N18 M105*30
    18:36:53.654 : ok T:205.9 /205.0 B:24.3 /-273.1 @:36
    18:36:56.723 : N19 M105*31
    18:36:56.723 : ok T:206.2 /205.0 B:24.4 /-273.1 @:41
    18:49:08.657 : N259 M105*41
    18:49:08.685 : ok T:205.0 /205.0 B:24.8 /-273.1 @:29
    18:49:10.680 : "C:\Program Files\Repetier-Host\plugins\RepetierServerConnector\RepetierServerStarter.exe" stop
    18:49:11.719 : N260 M105*35
    18:49:11.742 : ok T:204.8 /205.0 B:24.9 /-273.1 @:30
    18:49:14.782 : N261 M105*34
    18:49:14.796 : ok T:204.7 /205.0 B:24.9 /-273.1 @:34
    18:49:17.849 : N262 M105*33
    18:49:17.867 : ok T:204.8 /205.0 B:24.9 /-273.1 @:30
    18:49:20.907 : N263 M105*32
    18
    18:51:01.969 : N296 M105*42
    18:51:01.995 : ok T:205.2 /205.0 B:24.9 /-273.1 @:29
    18:51:05.032 : N297 M105*43
    18:51:05.049 : ok T:205.2 /205.0 B:24.8 /-273.1 @:29
    18:51:08.107 : N298 M105*36
    18:51:08.123 : ok T:205.1 /205.0 B:24.9 /-273.1 @:31
    18:51:11.193 : N299 M105*37
    18:51:11.209 : ok T:205.3 /205.0 B:24.9 /-273.1 @:27
    18:51:14.290 : N300 M105*36
    18:51:14.290 : ok T:205.3 /205.0 B:25.0 /-273.1 @:25
    18:51:17.352 : N301 M105*37
    18:51:17.368 : ok T:205.2 /205.0 B:24.8 /-273.1 @:28
    18:51:20.430 : N302 M105*38
    18:51:20.461 : ok T:205.1 /205.0 B:24.9 /-273.1 @:29
    18:51:21.680 : N303 G28*19
    18:51:23.493 : N304 M105*32
    18:51:26.555 : N305 M105*33
    18:51:27.118 : ok
    18:51:27.118 : ok T:205.3 /205.0 B:25.0 /-273.1 @:22
    18:51:29.602 : N306 M105*34
    18:51:29.618 : ok T:205.3 /205.0 B:25.0 /-273.1 @:22
    18:51:32.665 : N307 M105*35
    18:51:32.665 : ok T:205.0 /205.0 B:24.9 /-273.1 @:28
    18:51:35.727 : N308 M105*44
    18:51:35.743 : ok T:204.7 /205.0 B:24.9 /-273.1 @:32
    18:51:38.790 : N309 M105*45
    18:51:38.805 : ok T:204.5 /205.0 B:24.9 /-273.1 @:35
    18:51:41.852 : N310 M105*37
    18:51:41.868 : ok T:204.5 /205.0 B:24.9 /-273.1 @:32
    18:51:44.915 : N311 M105*36
    18:51:44.930 : ok T:204.4 /205.0 B:25.0 /-273.1 @:37
    18:51:47.984 : N312 M105*39
    18:51:48.000 : ok T:204.5 /205.0 B:25.0 /-273.1 @:36
    18:51:51.048 : N313 M105*38
    18:51:51.064 : ok T:205.0 /205.0 B:25.0 /-273.1 @:31
    18:51:54.126 : N314 M105*33
    18:51:54.142 : ok T:205.6 /205.0 B:24.9 /-273.1 @:20
    18:51:57.188 : N315 M105*32
    18:51:57.204 : ok T:205.7 /205.0 B:24.9 /-273.1 @:23
    18:52:00.256 : N316 M105*35
    18:52:00.272 : ok T:205.9 /205.0 B:25.0 /-273.1 @:20
    18:52:03.323 : N317 M105*34
    18:52:03.338 : ok T:205.8 /205.0 B:24.9 /-273.1 @:22
    18:52:06.379 : N318 M105*45
    18:52:06.395 : ok T:205.9 /205.0 B:25.0 /-273.1 @:20
    18:52:09.438 : N319 M105*44
    18:52:09.454 : ok T:205.4 /205.0 B:24.9 /-273.1 @:24
    18:52:12.547 : N320 M105*38
    18:52:12.563 : ok T:204.5 /205.0 B:24.9 /-273.1 @:36
    18:52:15.625 : N321 M105*39
    18:52:15.640 : ok T:204.2 /205.0 B:25.0 /-273.1 @:36
    18:52:18.700 : N322 M105*36
    18:52:18.715 : ok T:204.0 /205.0 B:25.0 /-273.1 @:37
    18:52:21.755 : N323 M105*37
    18:52:21.770 : ok T:203.5 /205.0 B:25.0 /-273.1 @:46
    18:52:24.836 : N324 M105*34
    18:52:24.859 : ok T:204.0 /205.0 B:25.0 /-273.1 @:38
    18:52:27.891 : N325 M105*35
    18:52:27.907 : ok T:204.4 /205.0 B:24.8 /-273.1 @:37
    18:52:30.954 : N326 M105*32
    18:52:30.969 : ok T:205.0 /205.0 B:25.0 /-273.1 @:31
    18:52:34.025 : N327 M105*33
    18:52:34.041 : ok T:205.5 /205.0 B:25.0 /-273.1 @:28
    18:52:37.087 : N328 M105*46
    18:52:37.103 : ok T:206.2 /205.0 B:25.0 /-273.1 @:21
    18:52:40.157 : N329 M105*47
    18:52:40.172 : ok T:206.3 /205.0 B:25.0 /-273.1 @:21
    18:52:43.219 : N330 M105*39
    18:52:43.219 : ok T:206.3 /205.0 B:24.9 /-273.1 @:18
    18:52:46.282 : N331 M105*38
    18:52:46.297 : ok T:206.2 /205.0 B:25.0 /-273.1 @:18
    18:52:49.348 : N332 M105*37
    18:52:49.348 : ok T:205.8 /205.0 B:24.9 /-273.1 @:21
    18:52:52.423 : N333 M105*36
    18:52:52.423 : ok T:205.3 /205.0 B:24.9 /-273.1 @:23
    18:52:55.489 : N334 M105*35
    18:52:55.505 : ok T:204.6 /205.0 B:24.8 /-273.1 @:29
    18:52:58.558 : N335 M105*34
    18:52:58.558 : ok T:203.9 /205.0 B:24.9 /-273.1 @:37
    18:53:01.622 : N336 M105*33
    18:53:01.622 : ok T:203.5 /205.0 B:25.0 /-273.1 @:42
    18:53:04.684 : N337 M105*32
    18:53:04.700 : ok T:203.4 /205.0 B:25.0 /-273.1 @:43
    18:53:07.747 : N338 M105*47
    18:53:07.747 : ok T:203.7 /205.0 B:24.9 /-273.1 @:42
    18:53:10.809 : N339 M105*46
    18:53:10.825 : ok T:204.2 /205.0 B:25.0 /-273.1 @:38
    18:53:13.874 : N340 M105*32
    18:53:13.896 : ok T:205.1 /205.0 B:25.0 /-273.1 @:30
    18:53:16.931 : N341 M105*33
    18:53:16.947 : ok T:205.9 /205.0 B:24.9 /-273.1 @:20
    18:53:19.994 : N342 M105*34
    18:53:20.009 : ok T:206.1 /205.0 B:24.9 /-273.1 @:23
    18:53:23.056 : N343 M105*35
    18:53:23.072 : ok T:206.2 /205.0 B:24.9 /-273.1 @:23
    18:53:26.129 : N344 M105*36
    18:53:26.129 : ok T:206.2 /205.0 B:24.9 /-273.1 @:20
    18:53:29.192 : N345 M105*37
    18:53:29.208 : ok T:205.8 /205.0 B:24.9 /-273.1 @:23
    18:53:32.254 : N346 M105*38
    18:53:32.254 : ok T:205.1 /205.0 B:25.0 /-273.1 @:30
    18:53:35.317 : N347 M105*39
    18:53:35.333 : ok T:205.0 /205.0 B:24.9 /-273.1 @:26
    18:53:38.379 : N348 M105*40
    18:53:38.395 : ok T:204.5 /205.0 B:24.9 /-273.1 @:33
    18:53:41.442 : N349 M105*41
    18:53:41.458 : ok T:204.5 /205.0 B:25.1 /-273.1 @:28
    18:53:44.504 : N350 M105*33
    18:53:44.520 : ok T:204.4 /205.0 B:25.0 /-273.1 @:30
    18:53:47.567 : N351 M105*32
    18:53:47.567 : ok T:204.4 /205.0 B:25.0 /-273.1 @:33
    18:53:50.629 : N352 M105*35
    18:53:50.645 : ok T:204.4 /205.0 B:24.9 /-273.1 @:36
    18:53:53.692 : N353 M105*34
    18:53:53.692 : ok T:204.3 /205.0 B:24.9 /-273.1 @:39
    18:53:56.754 : N354 M105*37
    18:53:56.770 : ok T:204.7 /205.0 B:25.0 /-273.1 @:34
    18:53:59.817 : N355 M105*36
    18:53:59.833 : ok T:204.9 /205.0 B:25.0 /-273.1 @:32
    18:54:02.879 : N356 M105*39
    18:54:02.895 : ok T:204.8 /205.0 B:25.0 /-273.1 @:37
    18:54:05.942 : N357 M105*38
    18:54:05.958 : ok T:205.2 /205.0 B:24.9 /-273.1 @:30
    18:54:09.004 : N358 M105*41
    18:54:09.020 : ok T:205.5 /205.0 B:24.9 /-273.1 @:27
    18:54:12.067 : N359 M105*40
    18:54:12.083 : ok T:206.3 /205.0 B:25.0 /-273.1 @:14
    18:54:15.129 : N360 M105*34
    18:54:15.129 : ok T:206.3 /205.0 B:24.9 /-273.1 @:16
    18:54:36.857 : Preferred name from C:\Users\Gustavo\Desktop\diseños\ironman2\torsovertical03height.gcode to torsovertical03height
    18:54:53.060 : N373 M117 ETE 1h 33m 28s*58
    18:54:53.091 : N374 M140 S45*84
    18:54:53.107 : ok
    18:54:53.107 : ok
    18:54:53.107 : N376 M190 S45*91
    18:54:53.107 : N377 M104 S235*98
    18:56:06.341 : ok
    18:56:06.341 : ok
    18:56:06.341 : N380 M117 ETE 1h 33m 28s*54
    18:56:06.357 : ok
    18:56:06.357 : N381 M109 S235*102
    18:56:06.357 : N382 M82*16
    18:56:06.357 : N383 G21*18
    18:56:06.357 : N384 G90*31
    18:56:34.888 : ok
    18:56:34.888 : ok
    18:56:34.888 : N385 M117 ETE 1h 33m 28s*51
    18:56:34.888 : ok
    18:56:34.888 : ok
    18:56:34.888 : N387 M82*21
    18:56:34.904 : ok
    18:56:34.904 : N388 M107*38
    18:56:34.904 : N389 G28 X0 Y0*16
    18:56:34.904 : ok
    18:56:34.904 : N390 G28 Z0*83
    18:56:34.919 : ok
    18:56:36.263 : ok
    18:56:36.263 : N391 M117 ETE 1h 33m 28s*54
    18:56:40.326 : ok
    18:56:40.326 : ok
    18:56:40.326 : N393 M117 ETE 1h 33m 28s*52
    18:56:40.357 : ok
    18:56:40.357 : N394 G1 Z15 F9000*55
    18:56:40.357 : N395 G92 E0*72
    18:56:40.357 : N396 G1 F200 E3*38
    18:56:40.357 : ok
    18:56:40.357 : N397 G92 E0*74
    18:56:40.373 : ok
    18:56:40.373 : ok
    18:56:40.373 : ok
    18:56:40.373 : N398 G1 F9000*69
    18:56:40.373 : N399 M117 Printing...*24
    18:56:40.373 : N400 G92 E0*67
    18:56:40.388 : ok
    18:56:40.388 : ok
    18:56:40.404 : ok
    18:56:40.404 : N401 G1 F1500 E-6.5*42
    18:56:40.404 : N402 M107*35
    18:56:40.419 : ok
    18:56:40.419 : ok
    18:56:40.419 : N403 G0 X105.64 Y50.695 Z0.36 F7200*36
    18:56:40.419 : N404 G1 F1500 E0*31
    18:56:40.435 : ok
    18:56:40.435 : ok
    18:56:40.435 : Imprimiendo capa 1 de 317
    18:56:40.435 : N405 G1 F2250 X106.052 Y49.884 E0.10892*59
    18:56:40.451 : ok
    18:56:40.451 : N406 G1 X106.608 Y48.955 E0.23855*85
    18:56:40.466 : ok
    18:56:40.466 : N407 G1 X107.206 Y48.105 E0.36299*92
    18:56:40.482 : ok
    18:56:40.482 : N408 G1 X107.304 Y47.978 E0.3822*97
    18:56:40.498 : ok
    18:56:40.498 : N409 G1 X107.885 Y47.274 E0.49149*95
    18:56:40.513 : ok
    18:56:40.513 : N410 G1 X108 Y47.145 E0.51219*77
    18:56:40.529 : ok
    18:56:40.544 : N411 G1 X108.61 Y46.506 E0.61796*102
    18:56:40.560 : ok
    18:56:40.560 : N412 G1 X109.403 Y45.783 E0.74646*80
    18:56:40.576 : ok
    18:56:40.576 : N413 G1 X110.249 Y45.117 E0.87538*92
    18:56:40.591 : ok
    18:56:40.591 : N414 G1 X111.139 Y44.517 E1.0039*97
    18:56:40.607 : ok
    18:56:40.607 : N415 G1 X112.034 Y44.005 E1.12736*82
    18:56:40.623 : ok
    18:56:40.623 : N416 G1 X112.183 Y43.927 E1.14749*92
    18:56:45.513 : ok
    18:56:45.513 : N418 M117 ETE 1h 33m 25s*61
    18:56:46.419 : ok
    18:56:46.419 : N420 G1 X113.151 Y43.474 E1.27546*81
    18:56:46.435 : ok
    18:56:46.435 : N421 G1 X113.997 Y43.147 E1.38406*92
    18:56:46.685 : ok
    18:56:46.685 : N422 G1 X114.169 Y43.088 E1.40584*87
    18:56:53.060 : ok
    18:56:53.060 : N424 M117 ETE 1h 33m 25s*50
    18:56:53.357 : ok
    18:56:53.357 : N425 G1 X115.019 Y42.828 E1.51227*90
    18:56:53.373 : ok
    18:56:53.373 : N426 G1 X115.179 Y42.786 E1.53207*85
    18:56:53.482 : ok
    18:56:53.482 : N427 G1 X116.086 Y42.583 E1.64336*86
    18:56:53.576 : ok
    18:56:53.576 : N428 G1 X116.733 Y42.422 E1.72319*80
    18:56:53.623 : ok
    18:56:53.623 : N429 G1 X117.228 Y42.239 E1.78638*95
    18:56:53.638 : ok
    18:56:53.638 : N430 G1 X117.677 Y42.046 E1.8449*96
    18:56:53.685 : ok
    18:56:53.685 : N431 G1 X118.083 Y41.888 E1.89707*90
    18:56:53.701 : ok
    18:56:53.701 : N432 G1 X118.446 Y41.731 E1.94442*87
    18:56:53.716 : ok
    18:56:53.716 : N433 G1 X119.113 Y41.418 E2.03264*85
    18:56:53.763 : ok
    18:56:53.763 : N434 G1 X119.948 Y41.09 E2.14006*96
    18:56:53.794 : ok
    18:56:53.810 : N435 G1 X120.11 Y41.032 E2.16066*98
    18:56:53.857 : ok
    18:56:53.857 : N436 G1 X120.96 Y40.767 E2.26727*105
    18:56:53.888 : ok
    18:56:53.888 : N437 G1 X121.129 Y40.722 E2.28821*90
    18:56:53.904 : ok
    18:56:53.904 : N438 G1 X121.994 Y40.519 E2.3946*104
    18:56:53.935 : ok
    18:56:53.935 : N439 G1 X122.165 Y40.485 E2.41547*83
    18:56:53.982 : ok
    18:56:53.982 : N440 G1 X123.049 Y40.346 E2.52262*89
    18:56:53.998 : ok
    18:56:53.998 : N441 G1 X123.212 Y40.327 E2.54227*84
    18:56:54.013 : ok
    18:56:54.013 : N442 G1 X124.361 Y40.243 E2.68021*93
    18:56:54.029 : ok
    18:56:54.029 : N443 G1 X125.194 Y40.113 E2.78116*87
    18:56:54.060 : ok
    18:56:54.060 : N444 G1 X126.217 Y39.846 E2.90775*89
    18:56:54.091 : ok
    18:56:54.091 : N445 G1 X127.229 Y39.605 E3.03232*80
    18:56:54.107 : ok
    18:56:54.107 : N446 G1 X128.37 Y39.378 E3.17161*110
    18:56:54.138 : ok
    18:56:54.138 : N447 G1 X130.142 Y39.099 E3.3864*96
    18:56:54.154 : ok
    18:56:54.154 : N448 G1 X131.875 Y38.894 E3.59535*81
    18:56:54.169 : ok
    18:56:54.169 : N449 G1 X132.844 Y38.806 E3.71185*95
    18:56:54.201 : ok
    18:56:54.201 : N450 G1 X133.887 Y38.785 E3.83676*91
    18:56:54.232 : ok
    18:56:54.232 : N451 G1 X134.072 Y38.788 E3.85892*80
    18:56:54.248 : ok
    18:56:54.248 : N452 G1 X135.112 Y38.852 E3.98368*95
    18:56:54.263 : ok
    18:56:54.263 : N453 G1 X136.01 Y38.969 E4.09211*103
    18:56:54.279 : ok
    18:56:54.279 : N454 G1 X136.178 Y38.997 E4.1125*98
    18:56:54.294 : ok
    18:56:54.294 : N455 G1 X137.227 Y39.218 E4.24086*89
    18:56:54.310 : ok
    18:56:54.310 : N456 G1 X138.225 Y39.505 E4.3652*102
    18:56:54.326 : ok
    18:56:54.326 : N457 G1 X139.088 Y39.819 E4.47516*80
    18:56:54.341 : ok
    18:56:54.341 : N458 G1 X139.251 Y39.885 E4.49622*86
    18:56:54.373 : ok
    18:56:54.373 : N459 G1 X140.216 Y40.323 E4.62311*95
    18:56:54.388 : ok
    18:56:54.388 : N460 G1 X141.047 Y40.774 E4.73632*80
    18:56:54.419 : ok
    18:56:54.419 : N461 G1 X141.642 Y41.077 E4.81627*94
    18:56:54.451 : ok
    18:56:54.451 : N462 G1 X142.269 Y41.303 E4.89607*89
    18:56:54.498 : ok
    18:56:54.498 : N463 G1 X142.656 Y41.425 E4.94466*90
    18:56:54.544 : ok
    18:56:54.544 : N464 G1 X144.127 Y41.988 E5.13325*94
    18:56:54.591 : ok
    18:56:54.591 : N465 G1 X144.132 Y41.973 E5.13514*91
    18:56:54.607 : ok
    18:56:54.607 : N466 G1 X144.282 Y42.026 E5.15419*80
    18:56:54.638 : ok
    18:56:54.638 : N467 G1 X144.583 Y42.089 E5.19101*82
    18:56:54.654 : ok
    18:56:54.654 : N468 G1 X144.583 Y42.105 E5.19293*80
    18:56:54.669 : ok
    18:56:54.669 : N469 G1 X146.069 Y42.365 E5.37356*82
    18:56:54.685 : ok
    18:56:54.685 : N470 G1 X147.083 Y42.622 E5.49881*81
    18:56:54.701 : ok
    18:56:54.701 : N471 G1 X147.435 Y42.735 E5.54308*88
    18:56:54.716 : ok
    18:56:54.716 : N472 G1 X148.083 Y42.902 E5.6232*104
    18:56:54.732 : ok
    18:56:54.732 : N473 G1 X148.761 Y42.986 E5.70501*88
    18:56:54.748 : ok
    18:56:54.748 : N474 G1 X149.443 Y42.984 E5.78667*84
    18:56:54.779 : ok
    18:56:54.779 : N475 G1 X150.121 Y42.896 E5.86853*86
    18:56:54.826 : ok
    18:56:54.826 : N476 G1 X150.782 Y42.724 E5.95031*82
    18:56:54.841 : ok
    18:56:54.841 : N477 G1 X151.414 Y42.469 E6.03191*83
    18:56:54.857 : ok
    18:56:54.857 : N478 G1 X151.928 Y42.189 E6.10199*95
    18:56:54.888 : ok
    18:56:54.888 : N479 G1 X152.715 Y41.7 E6.21294*85
    18:56:54.919 : ok
    18:56:54.919 : N480 G1 X152.886 Y41.602 E6.23654*95
    18:56:54.935 : ok
    18:56:54.935 : N481 G1 X153.655 Y41.198 E6.34055*90
    18:56:54.951 : ok
    18:56:54.951 : N482 G1 X153.818 Y41.121 E6.36213*94
    18:56:54.998 : ok
    18:56:54.998 : N483 G1 X154.639 Y40.764 E6.46933*93
    18:56:55.013 : ok
    18:56:55.013 : N484 G1 X154.784 Y40.707 E6.48798*89
    18:56:55.029 : ok
    18:56:55.029 : N485 G1 X155.652 Y40.402 E6.59814*94
    18:56:55.044 : ok
    18:56:55.044 : N486 M117 ETE 1h 33m 23s*60
    18:56:55.076 : ok
    18:56:55.076 : N487 G1 X155.8 Y40.357 E6.61666*82
    18:56:55.091 : ok
    18:56:55.091 : N488 G1 X156.676 Y40.12 E6.72532*99
    18:56:55.107 : ok
    18:56:55.107 : N489 G1 X156.831 Y40.084 E6.74438*93
    18:56:55.123 : ok
    18:56:55.138 : N490 G1 X157.865 Y39.888 E6.87039*86
    18:56:55.154 : ok
    18:56:55.154 : N491 G1 X158.77 Y39.782 E6.97949*105
    18:56:55.169 : ok
    18:56:55.169 : N492 G1 X158.936 Y39.769 E6.99943*87
    18:56:55.185 : ok
    18:56:55.185 : N493 G1 X159.843 Y39.728 E7.10814*82
    18:56:55.216 : ok
    18:56:55.216 : N494 G1 X160.895 Y39.751 E7.23413*81
    18:56:55.232 : ok
    18:56:55.232 : N495 G1 X161.086 Y39.763 E7.25705*88
    18:56:55.263 : ok
    18:56:55.263 : N496 G1 X162.125 Y39.875 E7.38218*93
    18:56:55.294 : ok
    18:56:55.294 : N497 G1 X163.003 Y40.029 E7.48891*91
    18:56:55.310 : ok
    18:56:55.310 : N498 G1 X163.188 Y40.069 E7.51157*89
    18:56:55.341 : ok
    18:56:55.341 : N499 G1 X164.05 Y40.286 E7.61801*97
    18:56:55.357 : ok
    18:56:55.357 : N500 G1 X164.216 Y40.334 E7.6387*108
    18:56:55.373 : ok
    18:56:55.373 : N501 G1 X165.082 Y40.619 E7.74786*89
    18:56:55.388 : ok
    18:56:55.388 : N502 G1 X165.636 Y40.824 E7.81859*84
    18:56:55.404 : ok
    18:56:55.404 : N503 G1 X166.476 Y41.165 E7.92714*89
    18:56:55.419 : ok
    18:56:55.419 : N504 G1 X166.678 Y41.257 E7.95372*83
    18:56:55.435 : ok
    18:56:55.435 : N505 G1 X167.927 Y41.899 E8.12187*86
    18:56:55.451 : ok
    18:56:55.451 : N506 G1 X168.425 Y42.186 E8.19069*91
    18:56:55.482 : ok
    18:56:55.482 : N507 G1 X168.665 Y42.336 E8.22458*91
    18:56:55.498 : ok
    18:56:55.498 : N508 G1 X169.14 Y42.598 E8.28953*107
    18:56:55.513 : ok
    18:56:55.513 : N509 G1 X170.043 Y43.073 E8.4117*103
    18:56:55.529 : ok
    18:56:55.529 : N510 G1 X170.196 Y43.162 E8.43289*80
    18:56:55.560 : ok
    18:56:55.560 : N511 G1 X170.972 Y43.649 E8.54259*86
    18:56:55.576 : ok
    18:56:55.576 : N512 G1 X171.102 Y43.738 E8.56145*80
    18:56:55.607 : ok
    18:56:55.607 : N514 G1 X171.818 Y44.266 E8.66797*87
    18:56:55.638 : ok
    18:56:55.638 : N515 G1 X172.319 Y44.661 E8.74436*87
    18:56:55.654 : ok
    18:56:55.654 : N516 G1 X172.325 Y44.655 E8.74538*83
    18:56:55.669 : ok
    18:56:55.669 : N517 G1 X172.456 Y44.753 E8.76497*80
    18:56:55.685 : ok
    18:56:55.685 : N518 G1 X172.671 Y44.896 E8.79589*95
    18:56:55.701 : ok
    18:56:55.701 : N519 G1 X173.526 Y45.515 E8.92227*95
    18:56:55.716 : ok
    18:56:55.716 : N520 G1 X174.201 Y46.077 E9.02744*90
    18:56:55.732 : ok
    18:56:55.732 : N521 G1 X174.345 Y46.206 E9.05059*82
    18:56:55.763 : ok
    18:56:55.763 : N522 G1 X175.386 Y47.064 E9.21212*83
    18:56:55.779 : ok
    18:56:55.779 : N523 G1 X175.518 Y47.182 E9.23332*91
    18:56:55.841 : ok
    18:56:55.841 : N524 G1 X176.149 Y47.787 E9.33799*88
    18:56:55.873 : ok
    18:56:55.873 : N525 G1 X176.288 Y47.932 E9.36204*83
    18:56:55.888 : ok
    18:56:55.888 : N526 G1 X177.243 Y49.024 E9.53574*85
    18:56:55.904 : ok
    18:56:55.904 : N527 G1 X177.499 Y49.349 E9.58528*95
    18:56:55.935 : ok
    18:56:55.935 : N528 G1 X177.884 Y49.861 E9.66198*83
    18:56:55.951 : ok
    18:56:55.951 : N529 G1 X178.233 Y50.345 E9.73343*94
    18:56:55.966 : ok
    18:56:55.966 : N530 G1 X178.786 Y51.168 E9.85215*90
    18:56:55.982 : ok
    18:56:55.982 : N531 G1 X179.092 Y51.663 E9.92183*94
    18:56:56.013 : ok
    18:56:56.013 : N532 G1 X179.635 Y52.618 E10.05337*98
    18:56:56.029 : ok
    18:56:56.029 : N533 G1 X179.964 Y53.288 E10.14274*98
    18:56:56.044 : ok
    18:56:56.044 : N534 G1 X180.224 Y53.861 E10.21809*103
    18:56:56.060 : ok
    18:56:56.060 : N535 G1 X180.649 Y54.895 E10.35194*109
    18:56:56.076 : ok
    18:56:56.076 : N536 G1 X180.944 Y55.775 E10.46307*96
    18:56:56.107 : ok
    18:56:56.107 : N537 G1 X181.227 Y56.774 E10.5874*84
    18:56:56.123 : ok
    18:56:56.123 : N538 G1 X181.271 Y56.954 E10.60958*104
    18:56:56.154 : ok
    18:56:56.154 : N539 G1 X181.447 Y57.822 E10.71563*111
    18:56:56.169 : ok
    18:56:56.169 : N540 G1 X181.48 Y58.02 E10.73967*101
    18:56:56.201 : ok
    18:56:56.201 : N541 G1 X181.592 Y58.889 E10.84458*100
    18:56:56.216 : ok
    18:56:56.216 : N542 G1 X181.609 Y59.072 E10.86658*107
    18:56:56.248 : ok
    18:56:56.248 : N543 G1 X181.656 Y59.941 E10.97079*108
    18:56:56.263 : ok
    18:56:56.263 : N544 G1 X181.66 Y60.122 E10.99246*89
    18:56:56.279 : ok
    18:56:56.279 : N545 G1 X181.635 Y61.176 E11.1187*86
    18:56:56.294 : ok
    18:56:56.294 : N546 G1 X181.553 Y62.068 E11.22596*110
    18:56:56.326 : ok
    18:56:56.326 : N547 G1 X181.53 Y62.25 E11.24792*99
    18:56:56.357 : ok
    18:56:56.357 : N548 G1 X181.353 Y63.288 E11.374*97
    18:56:56.388 : ok
    18:56:56.388 : N549 G1 X181.132 Y64.198 E11.48613*104
    18:56:56.419 : ok
    18:56:56.419 : N550 G1 X181.016 Y64.859 E11.56649*99
    18:56:56.435 : ok
    18:56:56.435 : N551 G1 X180.983 Y65.54 E11.64812*83
    18:56:56.498 : ok
    18:56:56.498 : N552 G1 X181.036 Y66.221 E11.72991*104
    18:56:56.529 : ok
    18:56:56.529 : N553 G1 X181.176 Y66.891 E11.81187*110
    18:56:56.576 : ok
    18:56:56.576 : N554 G1 X181.441 Y67.636 E11.90654*99
    18:56:56.591 : ok
    18:56:56.591 : N555 G1 X181.783 Y68.411 E12.00797*99
    18:56:56.623 : ok
    18:56:56.623 : N556 G1 X181.906 Y68.726 E12.04846*99
    18:56:56.638 : ok
    18:56:56.638 : N557 G1 X182.327 Y69.93 E12.20119*85
    18:56:56.654 : ok
    18:56:56.654 : N558 G1 X182.53 Y70.614 E12.28662*88
    18:56:56.669 : ok
    18:56:56.669 : N559 G1 X182.874 Y72.033 E12.46144*110
    18:56:56.701 : ok
    18:56:56.701 : N560 G1 X182.949 Y72.419 E12.50853*111
    18:56:56.716 : ok
    18:56:56.716 : N561 G1 X183.121 Y73.59 E12.65024*86
    18:56:56.748 : ok
    18:56:56.748 : N562 G1 X183.191 Y74.514 E12.7612*82
    18:56:56.779 : ok
    18:56:56.779 : N563 G1 X183.197 Y74.666 E12.77941*109
    18:56:56.794 : ok
    18:56:56.794 : N564 G1 X183.194 Y75.729 E12.90669*110
    18:56:56.810 : ok
    18:56:56.810 : N565 G1 X183.114 Y76.789 E13.03397*97
    18:56:56.841 : ok
    18:56:56.841 : N566 G1 X182.962 Y77.823 E13.15911*103
    18:56:56.873 : ok
    18:56:56.873 : N567 G1 X182.827 Y78.476 E13.23895*109
    18:56:56.888 : ok
    18:56:56.888 : N568 G1 X182.578 Y79.431 E13.35712*96
    18:56:56.919 : ok
    18:56:56.919 : N569 G1 X182.517 Y79.633 E13.38239*105
    18:56:56.935 : ok
    18:56:56.935 : N570 G1 X182.175 Y80.615 E13.5069*90
    18:56:56.966 : ok
    18:56:56.966 : N571 G1 X181.82 Y81.448 E13.61532*83
    18:56:56.998 : ok
    18:56:56.998 : N572 G1 X181.746 Y81.606 E13.63621*100
    18:56:57.013 : ok
    18:56:57.013 : N573 G1 X181.253 Y82.551 E13.76383*111
    18:56:57.044 : ok
    18:56:57.044 : N574 G1 X180.843 Y83.229 E13.8587*80
    18:56:57.060 : ok
    18:56:57.060 : N575 G1 X180.462 Y83.82 E13.9429*105
    18:56:57.107 : ok
    18:56:57.107 : N576 G1 X180.008 Y84.458 E14.03665*97
    18:56:57.123 : ok
    18:56:57.138 : N577 G1 X179.512 Y85.184 E14.14193*101
    18:56:57.185 : ok
    18:56:57.185 : N578 G1 X179.352 Y85.436 E14.17768*101
    18:56:57.216 : ok
    18:56:57.216 : N579 G1 X178.759 Y86.421 E14.31534*96
    18:56:57.232 : ok
    18:56:57.232 : N580 G1 X178.387 Y86.978 E14.39554*110
    18:56:57.263 : ok
    18:56:57.263 : N581 G1 X177.848 Y87.726 E14.50593*104
    18:56:57.294 : ok
    18:56:57.294 : N582 G1 X177.727 Y87.882 E14.52957*106
    18:56:57.326 : ok
    18:56:57.326 : N583 G1 X177.039 Y88.694 E14.657*109
    18:56:57.357 : ok
    18:56:57.357 : N584 G1 X176.428 Y89.326 E14.76226*97
    18:56:57.388 : ok
    18:56:57.388 : N585 G1 X176.279 Y89.469 E14.78699*96
    18:56:57.404 : ok
    18:56:57.404 : N586 G1 X175.951 Y89.761 E14.83957*99
    18:56:57.419 : ok
    18:56:57.419 : N587 G1 X175.481 Y90.237 E14.91967*108
    18:56:57.451 : ok
    18:56:57.451 : N588 G1 X175.066 Y90.78 E15.0015*98
    18:56:57.466 : ok
    18:56:57.466 : N589 G1 X174.723 Y91.37 E15.08321*82
    18:56:57.498 : ok
    18:56:57.498 : N590 G1 X174.458 Y92 E15.16505*115
    18:56:57.513 : ok
    18:56:57.513 : N591 G1 X174.272 Y92.661 E15.24727*96
    18:56:57.544 : ok
    18:56:57.544 : N592 G1 X174.162 Y93.525 E15.35155*96
    18:56:57.576 : ok
    18:56:57.576 : N593 G1 X174.134 Y94.166 E15.42838*100
    18:56:57.591 : ok
    18:56:57.591 : N594 G1 X174.067 Y94.786 E15.50305*106
    18:56:57.607 : ok
    18:56:57.607 : N595 G1 X174.009 Y95.373 E15.57368*96
    18:56:57.638 : ok
    18:56:57.638 : N596 G1 X173.974 Y95.635 E15.60533*108
    18:56:57.669 : ok
    18:56:57.669 : N597 G1 X173.888 Y96.396 E15.69702*105
    18:56:57.701 : ok
    18:56:57.701 : N598 G1 X173.846 Y96.682 E15.73164*105
    18:56:57.716 : ok
    18:56:57.716 : N599 G1 X173.773 Y97.258 E15.80116*106
    18:56:57.748 : ok
    18:56:57.748 : N600 G1 X173.729 Y97.852 E15.87247*102
    18:56:57.779 : ok
    18:56:57.779 : N601 G1 X173.576 Y98.933 E16.0032*90
    18:56:57.794 : ok
    18:56:57.794 : N602 G1 X173.353 Y99.964 E16.1295*85
    18:56:57.810 : ok
    18:56:57.810 : N603 G1 X173.311 Y100.127 E16.14966*95
    18:56:57.826 : ok
    18:56:57.826 : N604 G1 X173.001 Y101.138 E16.27627*95
    18:56:57.857 : ok
    18:56:57.857 : N605 G1 X172.64 Y102.08 E16.39706*80
    18:56:57.888 : ok
    18:56:57.888 : N606 G1 X172.553 Y102.285 E16.42373*95
    18:56:57.919 : ok
    18:56:57.919 : N607 G1 X172.324 Y102.937 E16.50647*91
    18:56:57.935 : ok
    18:56:57.935 : N608 G1 X172.184 Y103.418 E16.56646*90
    18:56:57.966 : ok
    18:56:57.966 : N609 G1 X171.828 Y104.403 E16.69186*93
    18:56:57.998 : ok
    18:56:57.998 : N610 G1 X171.656 Y104.795 E16.74312*93
    18:56:58.029 : ok
    18:56:58.029 : N611 G1 X170.915 Y106.57 E16.97343*103
    18:56:58.044 : ok
    18:56:58.044 : N612 G1 X170.067 Y108.291 E17.20315*80
    18:56:58.060 : ok
    18:56:58.060 : N613 G1 X169.63 Y109.047 E17.30771*98
    18:56:58.076 : ok
    18:56:58.076 : N614 G1 X169.279 Y109.637 E17.38991*85
    18:56:58.091 : ok
    18:56:58.091 : N615 G1 X168.805 Y110.395 E17.49695*92
    18:56:58.107 : ok
    18:56:58.107 : N616 G1 X168.694 Y110.556 E17.52037*84
    18:56:58.138 : ok
    18:56:58.138 : N617 G1 X168.064 Y111.405 E17.64696*82
    18:56:58.169 : ok
    18:56:58.169 : N618 G1 X167.488 Y112.081 E17.7533*102
    18:56:58.201 : ok
    18:56:58.201 : N619 G1 X167.37 Y112.21 E17.77423*90
    18:56:58.216 : ok
    18:56:58.216 : N620 G1 X166.624 Y112.959 E17.90081*86
    18:56:58.248 : ok
    18:56:58.248 : N621 G1 X166.069 Y113.452 E17.98969*88
    18:56:58.279 : ok
    18:56:58.279 : N622 G1 X165.384 Y114.022 E18.09639*81
    18:56:58.294 : ok
    18:56:58.294 : N623 G1 X165.056 Y114.314 E18.14897*92
    18:56:58.310 : ok
    18:56:58.310 : N624 G1 X164.599 Y114.75 E18.2246*89
    18:56:58.326 : ok
    18:56:58.326 : N625 G1 X163.899 Y115.363 E18.33601*82
    18:56:58.341 : ok
    18:56:58.341 : N626 G1 X163.153 Y115.97 E18.45117*103
    18:56:58.357 : ok
    18:56:58.357 : N627 G1 X163.026 Y116.066 E18.47023*92
    18:56:58.419 : ok
    18:56:58.419 : N628 G1 X162.276 Y116.591 E18.57985*92
    18:56:58.482 : ok
    18:56:58.482 : N629 G1 X161.354 Y117.145 E18.70864*88
    18:56:58.498 : ok
    18:56:58.513 : N630 G1 X161.23 Y117.213 E18.72558*99
    18:56:58.544 : ok
    18:56:58.544 : N631 G1 X160.402 Y117.627 E18.83642*81
    18:56:58.576 : ok
    18:56:58.576 : N632 G1 X159.921 Y117.858 E18.90031*82
    18:56:58.591 : ok
    18:56:58.591 : N633 G1 X159.301 Y118.188 E18.98441*91
    18:56:58.607 : ok
    18:56:58.607 : N634 G1 X158.421 Y118.617 E19.10163*93
    18:56:58.638 : ok
    18:56:58.638 : N635 G1 X158.247 Y118.693 E19.12436*81
    18:56:58.654 : ok
    18:56:58.654 : N637 G1 X157.834 Y118.854 E19.17744*84
    18:56:58.685 : ok
    18:56:58.685 : N638 G1 X157.223 Y119.136 E19.25802*87
    18:56:58.701 : ok
    18:56:58.701 : N639 G1 X156.538 Y119.578 E19.35563*95
    18:56:58.732 : ok
    18:56:58.732 : N640 G1 X155.921 Y120.048 E19.4485*97
    18:56:58.748 : ok
    18:56:58.748 : N641 G1 X155.414 Y120.487 E19.5288*102
    18:56:58.763 : ok
    18:56:58.763 : N642 G1 X154.959 Y120.996 E19.61055*93
    18:56:58.794 : ok
    18:56:58.794 : N643 G1 X154.574 Y121.554 E19.69172*80
    18:56:58.826 : ok
    18:56:58.826 : N644 G1 X154.367 Y121.931 E19.74322*87
    18:56:58.841 : ok
    18:56:58.841 : N645 G1 X154.06 Y122.552 E19.82616*99
    18:56:58.873 : ok
    18:56:58.873 : N646 G1 X153.525 Y123.469 E19.95328*85
    18:56:58.904 : ok
    18:56:58.904 : N647 G1 X153.442 Y123.599 E19.97175*82
    18:56:58.919 : ok
    18:56:58.919 : N648 G1 X152.931 Y124.336 E20.07913*90
    18:56:58.951 : ok
    18:56:58.951 : N649 G1 X152.821 Y124.484 E20.10121*90
    18:56:58.966 : ok
    18:56:58.966 : N650 G1 X152.256 Y125.182 E20.20874*80
    18:56:58.982 : ok
    18:56:58.982 : N651 G1 X152.144 Y125.311 E20.22919*81
    18:56:59.029 : ok
    18:56:59.029 : N652 G1 X151.542 Y125.955 E20.33475*94
    18:56:59.044 : ok
    18:56:59.044 : N653 G1 X151.411 Y126.085 E20.35684*85
    18:56:59.060 : ok
    18:56:59.060 : N654 G1 X150.768 Y126.679 E20.46166*84
    18:56:59.076 : ok
    18:56:59.076 : N655 G1 X150.621 Y126.805 E20.48484*91
    18:56:59.091 : ok
    18:56:59.091 : N656 G1 X149.94 Y127.347 E20.58905*97
    18:56:59.123 : ok
    18:56:59.123 : N657 G1 X149.779 Y127.466 E20.61303*86
    18:56:59.154 : ok
    18:56:59.154 : N658 G1 X148.919 Y128.048 E20.73736*86
    18:56:59.169 : ok
    18:56:59.185 : N659 G1 X148.13 Y128.505 E20.84654*101
    18:56:59.216 : ok
    18:56:59.216 : N660 G1 X147.973 Y128.589 E20.86786*87
    18:56:59.232 : ok
    18:56:59.232 : N661 G1 X147.686 Y128.728 E20.90604*86
    18:56:59.248 : ok
    18:56:59.248 : N662 G1 X147.072 Y129.08 E20.99078*104
    18:56:59.294 : ok
    18:56:59.294 : N663 G1 X146.291 Y129.593 E21.10267*92
    18:56:59.310 : ok
    18:56:59.310 : N664 G1 X145.373 Y130.106 E21.22858*82
    18:56:59.326 : ok
    18:56:59.326 : N665 G1 X144.392 Y130.564 E21.35822*86
    18:56:59.341 : ok
    18:56:59.341 : N666 G1 X143.556 Y130.887 E21.46553*83
    18:56:59.373 : ok
    18:56:59.373 : N667 G1 X143.402 Y130.94 E21.48503*99
    18:56:59.388 : ok
    18:56:59.388 : N668 G1 X142.507 Y131.212 E21.59703*86
    18:56:59.404 : ok
    18:56:59.404 : N669 G1 X141.511 Y131.442 E21.71943*80
    18:56:59.419 : ok
    18:56:59.419 : N670 G1 X141.316 Y131.478 E21.74317*94
    18:56:59.451 : ok
    18:56:59.451 : N671 G1 X140.293 Y131.627 E21.86695*88
    18:56:59.466 : ok
    18:56:59.466 : N672 G1 X139.37 Y131.697 E21.97779*97
    18:56:59.482 : ok
    18:56:59.482 : N673 G1 X139.218 Y131.703 E21.996*82
    18:56:59.498 : ok
    18:56:59.498 : N674 G1 X138.157 Y131.702 E22.12304*92
    18:56:59.529 : ok
    18:56:59.529 : N675 G1 X137.253 Y131.638 E22.23156*90
    18:56:59.560 : ok
    18:56:59.560 : N676 G1 X136.046 Y131.466 E22.37754*86
    18:56:59.576 : ok
    18:56:59.576 : N677 G1 X134.985 Y131.227 E22.50776*81
    18:56:59.591 : ok
    18:56:59.591 : N678 G1 X133.997 Y130.929 E22.63133*89
    18:56:59.607 : ok
    18:56:59.607 : N679 G1 X133.133 Y130.602 E22.74194*83
    18:56:59.623 : ok
    18:56:59.623 : N680 G1 X132.959 Y130.528 E22.76458*92
    18:56:59.654 : ok
    18:56:59.654 : N681 G1 X132.176 Y130.164 E22.86797*91
    18:56:59.685 : ok
    18:56:59.685 : N682 G1 X131.997 Y130.072 E22.89207*89
    18:56:59.701 : ok
    18:56:59.701 : N683 G1 X131.405 Y129.732 E22.97381*85
    18:56:59.716 : ok
    18:56:59.716 : N684 G1 X130.804 Y129.435 E23.05408*86
    18:56:59.732 : ok
    18:56:59.732 : N685 G1 X130.159 Y129.213 E23.13575*88
    18:56:59.763 : ok
    18:56:59.763 : N686 G1 X129.49 Y129.075 E23.21754*97
    18:56:59.779 : ok
    18:56:59.779 : N687 G1 X128.806 Y129.022 E23.29969*88
    18:56:59.794 : ok
    18:56:59.794 : N688 G1 X128.559 Y129.013 E23.32928*93
    18:56:59.826 : ok
    18:56:59.826 : N689 G1 X127.686 Y128.937 E23.43421*94
    18:56:59.857 : ok
    18:56:59.857 : N690 G1 X127.487 Y128.912 E23.45822*91
    18:56:59.873 : ok
    18:56:59.873 : N691 G1 X126.635 Y128.775 E23.56155*84
    18:56:59.904 : ok
    18:56:59.904 : N692 G1 X126.436 Y128.736 E23.58583*80
    18:56:59.951 : ok
    18:56:59.951 : N693 G1 X125.321 Y128.465 E23.72322*83
    18:56:59.982 : ok
    18:56:59.982 : N694 G1 X124.931 Y128.35 E23.77191*96
    18:57:00.013 : ok
    18:57:00.013 : N695 G1 X123.533 Y127.871 E23.94885*94
    18:57:00.044 : ok
    18:57:00.044 : N696 G1 X123.007 Y127.659 E24.01676*82
    18:57:00.060 : ok
    18:57:00.060 : N697 G1 X122.17 Y127.292 E24.12619*107
    18:57:00.076 : ok
    18:57:00.076 : N698 M117 ETE 1h 33m 19s*56
    18:57:00.091 : ok
    18:57:00.091 : N699 G1 X122.015 Y127.217 E24.14681*93
    18:57:00.107 : ok
    18:57:00.107 : N700 G1 X121.083 Y126.717 E24.27345*89
    18:57:00.123 : ok
    18:57:00.123 : N701 G1 X119.894 Y125.971 E24.44151*82
    18:57:00.138 : ok
    18:57:00.138 : N702 G1 X119.884 Y125.987 E24.44377*95
    18:57:00.154 : ok
    18:57:00.154 : N703 G1 X119.068 Y125.63 E24.55042*98
    18:57:00.169 : ok
    18:57:00.169 : N704 G1 X117.991 Y125.273 E24.68628*83
    18:57:00.185 : ok
    18:57:00.185 : N705 G1 X117.086 Y124.937 E24.80186*82
    18:57:00.201 : ok
    18:57:00.201 : N706 G1 X115.978 Y124.429 E24.94781*93
    18:57:00.216 : ok
    18:57:00.216 : N707 G1 X115.188 Y123.994 E25.0558*109
    18:57:00.232 : ok
    18:57:00.232 : N708 G1 X115.038 Y123.904 E25.07674*91
    18:57:00.248 : ok
    18:57:00.248 : N709 G1 X114.161 Y123.329 E25.20231*83
    18:57:00.263 : ok
    18:57:00.263 : N710 G1 X113.428 Y122.776 E25.31225*94
    18:57:00.279 : ok
    18:57:00.279 : N711 G1 X112.803 Y122.274 E25.40824*81
    18:57:00.310 : ok
    18:57:00.310 : N712 G1 X112.65 Y122.141 E25.43251*100
    18:57:00.326 : ok
    18:57:00.326 : N713 G1 X112.362 Y121.91 E25.47672*111
    18:57:00.373 : ok
    18:57:00.373 : N714 G1 X111.217 Y121.056 E25.64775*84
    18:57:00.388 : ok
    18:57:00.388 : N715 G1 X110.49 Y120.473 E25.75933*99
    18:57:00.404 : ok
    18:57:00.404 : N716 G1 X110.35 Y120.351 E25.78156*106
    18:57:00.419 : ok
    18:57:00.419 : N717 G1 X109.728 Y119.773 E25.88323*89
    18:57:00.451 : ok
    18:57:00.451 : N718 G1 X109.567 Y119.612 E25.91049*94
    18:57:00.498 : ok
    18:57:00.513 : N719 G1 X108.985 Y118.986 E26.01284*84
    18:57:00.529 : ok
    18:57:00.529 : N720 G1 X108.854 Y118.833 E26.03696*89
    18:57:00.576 : ok
    18:57:00.576 : N721 G1 X108.316 Y118.161 E26.14003*87
    18:57:00.607 : ok
    18:57:00.607 : N722 G1 X108.194 Y117.996 E26.1646*96
    18:57:00.638 : ok
    18:57:00.638 : N723 G1 X107.701 Y117.281 E26.26859*92
    18:57:00.669 : ok
    18:57:00.669 : N724 G1 X107.591 Y117.108 E26.29314*95
    18:57:00.685 : ok
    18:57:00.685 : N725 G1 X107.081 Y116.225 E26.41523*91
    18:57:00.716 : ok
    18:57:00.716 : N726 G1 X106.669 Y115.387 E26.52704*86
    18:57:00.748 : ok
    18:57:00.748 : N727 G1 X106.605 Y115.243 E26.54591*92
    18:57:00.763 : ok
    18:57:00.763 : N728 G1 X106.275 Y114.421 E26.65197*83
    18:57:00.779 : ok
    18:57:00.779 : N729 G1 X106.206 Y114.228 E26.67651*86
    18:57:00.794 : ok
    18:57:00.794 : N730 G1 X105.945 Y113.415 E26.77875*87
    18:57:00.841 : ok
    18:57:00.841 : N731 G1 X105.893 Y113.229 E26.80188*86
    18:57:00.873 : ok
    18:57:00.873 : N732 G1 X105.686 Y112.37 E26.90767*101
    18:57:00.888 : ok
    18:57:00.888 : N733 G1 X105.653 Y112.208 E26.92747*82
    18:57:00.904 : ok
    18:57:00.904 : N734 G1 X105.502 Y111.305 E27.03709*94
    18:57:00.919 : ok
    18:57:00.919 : N735 G1 X105.482 Y111.148 E27.05604*87
    18:57:00.951 : ok
    18:57:00.951 : N736 G1 X105.401 Y110.265 E27.16221*83
    18:57:00.966 : ok
    18:57:00.966 : N737 G1 X105.388 Y109.883 E27.20798*92
    18:57:00.998 : ok
    18:57:00.998 : N738 G1 X105.335 Y109.215 E27.28822*86
    18:57:01.013 : ok
    18:57:01.013 : N739 G1 X105.194 Y108.546 E27.37008*80
    18:57:01.029 : ok
    18:57:01.029 : N740 G1 X104.971 Y107.901 E27.45179*94
    18:57:01.044 : ok
    18:57:01.044 : N741 G1 X104.668 Y107.29 E27.53346*98
    18:57:01.076 : ok
    18:57:01.076 : N742 G1 X104.29 Y106.721 E27.61525*110
    18:57:01.123 : ok
    18:57:01.123 : N743 G1 X103.845 Y106.205 E27.69684*89
    18:57:01.138 : ok
    18:57:01.138 : N744 G1 X103.4 Y105.801 E27.7688*106
    18:57:01.169 : ok
    18:57:01.185 : N745 G1 X103.161 Y105.599 E27.80627*95
    18:57:01.201 : ok
    18:57:01.201 : N746 G1 X102.516 Y104.991 E27.9124*105
    18:57:01.216 : ok
    18:57:01.216 : N747 G1 X102.394 Y104.867 E27.93323*90
    18:57:01.232 : ok
    18:57:01.232 : N748 G1 X101.781 Y104.201 E28.04161*89
    18:57:01.263 : ok
    18:57:01.263 : N749 G1 X101.151 Y103.412 E28.16251*83
    18:57:01.279 : ok
    18:57:01.279 : N750 G1 X100.701 Y102.911 E28.24314*87
    18:57:01.310 : ok
    18:57:01.310 : N751 G1 X100.008 Y102.338 E28.35081*86
    18:57:01.326 : ok
    18:57:01.326 : N752 G1 X99.899 Y102.264 E28.36658*109
    18:57:01.341 : ok
    18:57:01.341 : N753 G1 X98.959 Y101.547 E28.50814*99
    18:57:01.357 : ok
    18:57:01.357 : N754 G1 X98.222 Y100.901 E28.62549*104
    18:57:01.388 : ok
    18:57:01.388 : N755 G1 X97.471 Y100.15 E28.75266*86
    18:57:01.404 : ok
    18:57:01.404 : N756 G1 X96.81 Y99.39 E28.87326*88
    18:57:01.419 : ok
    18:57:01.419 : N757 G1 X96.184 Y98.573 E28.9965*108
    18:57:01.451 : ok
    18:57:01.451 : N758 G1 X95.718 Y97.885 E29.096*85
    18:57:01.466 : ok
    18:57:01.466 : N759 G1 X95.295 Y97.214 E29.19097*95
    18:57:01.498 : ok
    18:57:01.498 : N760 G1 X94.793 Y96.351 E29.31051*86
    18:57:01.513 : ok
    18:57:01.513 : N761 G1 X94.71 Y96.195 E29.33167*96
    18:57:01.529 : ok
    18:57:01.529 : N762 G1 X94.3 Y95.351 E29.44402*89
    18:57:01.544 : ok
    18:57:01.544 : N763 G1 X93.912 Y94.386 E29.56856*83
    18:57:01.560 : ok
    18:57:01.560 : N764 G1 X93.855 Y94.225 E29.58901*83
    18:57:01.576 : ok
    18:57:01.576 : N765 G1 X93.594 Y93.399 E29.69273*95
    18:57:01.607 : ok
    18:57:01.607 : N766 G1 X93.54 Y93.207 E29.71661*109
    18:57:01.623 : ok
    18:57:01.623 : N767 G1 X93.304 Y92.189 E29.84174*87
    18:57:01.654 : ok
    18:57:01.654 : N768 G1 X93.156 Y91.272 E29.95296*86
    18:57:01.669 : ok
    18:57:01.669 : N769 G1 X93.059 Y90.218 E30.07969*92
    18:57:01.701 : ok
    18:57:01.701 : N770 G1 X93.04 Y89.153 E30.20723*109
    18:57:01.732 : ok
    18:57:01.732 : N772 G1 X93.095 Y88.122 E30.33085*89
    18:57:01.779 : ok
    18:57:01.779 : N773 G1 X93.217 Y87.112 E30.45267*83
    18:57:01.794 : ok
    18:57:01.794 : N774 G1 X93.416 Y85.875 E30.60269*80
    18:57:01.826 : ok
    18:57:01.841 : N775 G1 X93.594 Y84.973 E30.71277*83
    18:57:01.873 : ok
    18:57:01.873 : N776 G1 X93.871 Y83.942 E30.8406*109
    18:57:01.904 : ok
    18:57:01.904 : N777 G1 X93.927 Y83.764 E30.86294*95
    18:57:01.935 : ok
    18:57:01.935 : N778 G1 X94.222 Y82.931 E30.96875*82
    18:57:01.951 : ok
    18:57:01.951 : N779 G1 X94.457 Y82.337 E31.04524*88
    18:57:01.982 : ok
    18:57:01.982 : N780 G1 X94.449 Y82.333 E31.04631*82
    18:57:02.013 : ok
    18:57:02.013 : N781 G1 X94.774 Y81.555 E31.14726*93
    18:57:02.029 : ok
    18:57:02.029 : N782 G1 X95.028 Y80.922 E31.22893*88
    18:57:02.044 : ok
    18:57:02.044 : N783 G1 X95.108 Y80.742 E31.25252*82
    18:57:02.060 : ok
    18:57:02.060 : N784 G1 X95.498 Y79.946 E31.35865*90
    18:57:02.076 : ok
    18:57:02.076 : N785 G1 X95.582 Y79.789 E31.37997*82
    18:57:02.091 : ok
    18:57:02.091 : N786 G1 X96.028 Y78.999 E31.4886*104
    18:57:02.107 : ok
    18:57:02.107 : N787 G1 X96.316 Y78.395 E31.56872*93
    18:57:02.138 : ok
    18:57:02.138 : N788 G1 X96.529 Y77.748 E31.65028*84
    18:57:02.169 : ok
    18:57:02.169 : N789 G1 X96.639 Y77.214 E31.71556*82
    18:57:02.216 : ok
    18:57:02.216 : N790 G1 X96.703 Y76.797 E31.76608*82
    18:57:02.248 : ok
    18:57:02.248 : N791 G1 X96.746 Y76.577 E31.79292*86
    18:57:02.294 : ok
    18:57:02.294 : N792 G1 X97.04 Y75.347 E31.94434*106
    18:57:02.326 : ok
    18:57:02.326 : N793 G1 X97.42 Y74.009 E32.11088*108
    18:57:02.357 : ok
    18:57:02.357 : N794 G1 X97.711 Y72.81 E32.25862*103
    18:57:02.373 : ok
    18:57:02.373 : N795 G1 X97.953 Y71.942 E32.36651*87
    18:57:02.404 : ok
    18:57:02.404 : N796 G1 X98.012 Y71.756 E32.38988*89
    18:57:02.419 : ok
    18:57:02.419 : N797 G1 X98.31 Y70.931 E32.4949*85
    18:57:02.466 : ok
    18:57:02.466 : N798 G1 X98.382 Y70.752 E32.51801*87
    18:57:02.482 : ok
    18:57:02.482 : N799 G1 X98.747 Y69.931 E32.62559*88
    18:57:02.498 : ok
    18:57:02.513 : N800 G1 X98.824 Y69.774 E32.64653*93
    18:57:02.544 : ok
    18:57:02.544 : N801 G1 X99.316 Y68.868 E32.76997*80
    18:57:02.560 : ok
    18:57:02.560 : N802 G1 X99.898 Y67.96 E32.89911*102
    18:57:02.576 : ok
    18:57:02.576 : N803 G1 X100.431 Y67.24 E33.00637*91
    18:57:02.607 : ok
    18:57:02.607 : N804 G1 X100.545 Y67.099 E33.02808*104
    18:57:02.623 : ok
    18:57:02.623 : N805 G1 X101.118 Y66.434 E33.13319*109
    18:57:02.638 : ok
    18:57:02.638 : N806 G1 X101.255 Y66.286 E33.15733*97
    18:57:02.654 : ok
    18:57:02.654 : N807 G1 X102.229 Y65.309 E33.32252*106
    18:57:02.669 : ok
    18:57:02.669 : N808 G1 X102.219 Y65.299 E33.32421*108
    18:57:02.716 : ok
    18:57:02.716 : N809 G1 X102.278 Y65.237 E33.33446*110
    18:57:02.748 : ok
    18:57:02.748 : N810 G1 X102.685 Y64.688 E33.41629*111
    18:57:02.763 : ok
    18:57:02.763 : N811 G1 X103.018 Y64.093 E33.49793*105
    18:57:02.794 : ok
    18:57:02.794 : N812 G1 X103.274 Y63.459 E33.5798*84
    18:57:02.826 : ok
    18:57:02.826 : N813 G1 X103.448 Y62.798 E33.66164*99
    18:57:02.841 : ok
    18:57:02.841 : N814 G1 X103.537 Y62.122 E33.74328*99
    18:57:02.873 : ok
    18:57:02.873 : N815 G1 X103.54 Y61.442 E33.8247*97
    18:57:02.888 : ok
    18:57:02.888 : N816 G1 X103.488 Y60.948 E33.88418*101
    18:57:02.904 : ok
    18:57:02.904 : N817 G1 X103.439 Y60.583 E33.92827*110
    18:57:02.919 : ok
    18:57:02.919 : N818 G1 X103.371 Y59.693 E34.03515*97
    18:57:02.951 : ok
    18:57:02.951 : N819 G1 X103.364 Y59.506 E34.05756*104
    18:57:02.982 : ok
    18:57:02.982 : N820 G1 X103.365 Y58.46 E34.1828*97
    18:57:03.013 : ok
    18:57:03.013 : N821 G1 X103.422 Y57.595 E34.2866*89
    18:57:03.029 : ok
    18:57:03.029 : N822 G1 X103.563 Y56.495 E34.41939*98
    18:57:03.044 : ok
    18:57:03.044 : N823 G1 X103.74 Y55.608 E34.52769*92
    18:57:03.060 : ok
    18:57:03.060 : N824 G1 X104.021 Y54.567 E34.65679*99
    18:57:03.107 : ok
    18:57:03.107 : N825 G1 X104.334 Y53.644 E34.77349*101
    18:57:03.123 : ok
    18:57:03.123 : N826 G1 X104.725 Y52.666 E34.89961*98
    18:57:03.138 : ok
    18:57:03.138 : N827 G1 X105.087 Y51.897 E35.00138*106
    18:57:03.169 : ok
    18:57:03.169 : N828 G1 X105.232 Y51.613 E35.03956*104
    18:57:03.185 : ok
    18:57:03.185 : N829 G1 X105.394 Y51.265 E35.08552*98
    18:57:03.232 : ok
    18:57:03.232 : N830 G1 X105.64 Y50.695 E35.15985*86
    18:57:03.248 : ok
    18:57:03.248 : N831 G0 X105.6 Y50.787 F7200*126
    18:57:03.279 : ok
    18:57:03.279 : N832 G1 F2250 X105.6 Y111.891 E42.47623*57
    18:57:03.294 : ok
    18:57:03.294 : N833 G0 X107.2 Y116.431 F7200*71
    18:57:03.310 : ok
    18:57:03.310 : N834 G1 F2250 X107.2 Y48.113 E50.65639*15
    18:57:03.326 : ok
    18:57:03.326 : N835 G0 X108.8 Y46.332 F7200*116
    18:57:03.341 : ok
    18:57:03.341 : N836 G1 F2250 X108.8 Y118.765 E59.32926*49
    18:57:03.373 : ok
    18:57:03.373 : N837 G0 X110.4 Y120.394 F7200*78
    18:57:03.404 : ok
    18:57:03.404 : N838 G1 F2250 X110.4 Y45.015 E68.35488*15
    18:57:03.435 : ok
    18:57:03.435 : N839 G0 X112 Y44.024 F7200*99
    18:57:03.482 : ok
    18:57:03.482 : N840 G1 F2250 X112 Y121.64 E77.64834*28
    18:57:03.513 : ok
    18:57:03.513 : N841 G0 X113.6 Y122.905 F7200*78
    18:57:03.560 : ok
    18:57:03.560 : N842 G1 F2250 X113.6 Y43.3 E87.17997*0
    18:57:03.623 : ok
    18:57:03.623 : N843 G0 X115.2 Y42.781 F7200*123
    18:57:03.669 : ok
    18:57:03.669 : N844 G1 F2250 X115.2 Y124 E96.90485*40
    18:57:03.701 : ok
    18:57:03.701 : N845 G0 X116.8 Y124.805 F7200*70
    18:57:03.732 : ok
    18:57:03.732 : N846 G1 F2250 X116.8 Y42.397 E106.77209*50
    18:57:03.794 : ok
    18:57:03.794 : N847 G0 X118.4 Y41.75 F7200*75
    18:57:03.810 : ok
    18:57:03.810 : N848 G1 F2250 X118.4 Y125.408 E116.789*3
    18:57:05.794 : ok
    18:57:05.794 : N850 M117 ETE 1h 32m 57s*57
    18:57:06.185 : ok
    18:57:06.185 : N851 G0 X120 Y126.037 F7200*91
    18:57:06.201 : ok
    18:57:06.201 : N852 G1 F2250 X120 Y41.071 E126.96254*41
    18:57:08.419 : ok
    18:57:08.419 : N854 G0 X121.6 Y40.611 F7200*116
    18:57:08.654 : ok
    18:57:08.654 : N855 G1 F2250 X121.6 Y126.994 E137.30573*11
    18:57:10.998 : ok
    18:57:10.998 : N856 M117 ETE 1h 32m 52s*58
    18:57:11.185 : ok
    18:57:11.185 : N858 G0 X123.2 Y127.736 F7200*74
    18:57:11.216 : ok
    18:57:11.216 : N859 G1 F2250 X123.2 Y40.328 E147.77166*57
    18:57:13.669 : ok
    18:57:13.669 : N860 G0 X124.8 Y40.174 F7200*124
    18:57:13.857 : ok
    18:57:13.857 : N861 G1 F2250 X124.8 Y128.305 E158.32416*2
    18:57:16.373 : ok
    18:57:16.373 : N863 M117 ETE 1h 32m 47s*56
    18:57:16.576 : ok
    18:57:16.576 : N864 G0 X126.4 Y128.727 F7200*73
    18:57:16.576 : ok
    18:57:16.576 : N865 G1 F2250 X126.4 Y39.802 E168.97172*62
    18:57:19.154 : ok
    18:57:19.154 : N867 G0 X128 Y39.451 F7200*109
    18:57:19.357 : ok
    18:57:19.357 : N868 G1 F2250 X128 Y128.964 E179.68969*21
    18:57:59.466 : Communication timeout - reset send buffer block
    18:57:59.466 : N870 M117 ETE 1h 32m 42s*63
    18:58:38.544 : Se ha denegado el acceso al puerto 'COM3'.
  • You see the firmware stopped responding with "ok" so no line could be send. Even after sending next line no more answers. The fact that you also could not reconnect if I interpret that last line correctly shows that windows has problems with the communication. So the problem occured outside the host, but it is impossible to say what it is. Noise, erronous communication crashing driver, .... Maybe driver got updated or you made changes to printer firmware/hardware?
    No chagnes were made. Now I have formated windows and installed Win7 again. Installed drivers, installed last version of repetier... and tried to connect... I got the "timeout" message again.. but it connected later...
    I got this log:
    12:53:03.050 : OpenGL version:4.6.0 NVIDIA 425.31
    12:53:03.050 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
    12:53:03.050 : OpenGL renderer:GeForce GTX 650/PCIe/SSE2
    12:53:03.050 : Using fast VBOs for rendering is possible
    12:54:42.847 : Printer reset detected - initalizing
    12:54:42.894 : start
    12:54:42.894 : echo: External Reset
    12:54:42.894 : Marlin 1.0.1 RRP
    12:54:42.894 : echo: Last Updated: 2014-07-05-Lankeda-i3 | Author: Sim Wang
    12:54:42.894 : echo: Free Memory: 11513  PlannerBufferBytes: 1232
    12:54:42.894 : echo:Stored settings retreived:
    12:54:42.894 : echo:Steps per unit:
    12:54:42.894 : echo:  M92 X100.000 Y100.000 Z2560.000 E100.000
    12:54:42.894 : echo:Maximum feedrates (mm/s):
    12:54:42.894 : echo:  M203 X300.000 Y300.000 Z3.000 E45.000
    12:54:42.894 : echo:Maximum Acceleration (mm/s2):
    12:54:43.003 : ?start
    12:54:43.003 : echo: External Reset
    12:54:43.003 : Marlin 1.0.1 RRP
    12:54:43.003 : echo: Last Updated: 2014-07-05-Lankeda-i3 | Author: Sim Wang
    12:54:43.003 : echo: Free Memory: 11513  PlannerBufferBytes: 1232
    12:54:43.003 : echo:Stored settings retreived:
    12:54:43.003 : echo:Steps per unit:
    12:54:43.003 : echo:  M92 X100.000 Y100.000 Z2560.000 E100.000
    12:54:43.003 : echo:Maximum feedrates (mm/s):
    12:54:43.003 : echo:  M203 X300.000 Y300.000 Z3.000 E45.000
    12:54:43.003 : echo:Maximum Acceleration (mm/s2):
    12:54:43.003 : echo:  M201 X800 Y50 Z30 E250
    12:54:43.019 : echo:Acceleration: S=acceleration, T=retract acceleration
    12:54:43.019 : echo:  M204 S1000.000 T1000.000
    12:54:43.019 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s),  Z=maximum Z jerk (mm/s), K=advance_k
    12:54:43.019 : echo:  M205 S0.000 T0.000 B20000 X15.000 Z0.400 E15.000
    12:54:43.019 : echo:  M206 X0.000 Y0.000 Z0.000
    12:54:43.019 : echo:  M208 X210.000 Y210.000 Z160.000
    12:54:43.019 : echo:PID settings:
    12:54:43.019 : echo:   M301 P12.000 I2.200 D80.000 W125
    12:54:43.019 : echo:Thermistor settings: M304 Hh Bb Rr Tt, H0=Bed, H1..n=nozzle, b=thermistor beta value, r=series resistor, t=thermistor resistance as 25C
    12:54:43.019 : echo: M304 H0
    12:54:43.019 : B3960 R10000 T100000 M304 H1
    12:54:43.019 : FPU Enabled no
    12:54:45.363 : transform correction not enabledecho:SD init fail
    12:54:45.410 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1
    12:54:45.441 : X:0.000Y:0.000Z:0.000E:0.000 Count X:0.000Y:0.000Z:0.000
    12:54:45.441 : echo:Active Extruder: 0
    12:55:29.253 : Communication timeout - reset send buffer block
    12:56:17.457 : Error:checksum mismatch, Last Line:15
    12:56:17.457 : Resend:16
    The thing is that the timeout message keeps showing after a windows reinstallation... I will check printing something to see if it stops randomly again and I will post updates. Thank you!
  • In my case the problem was "solved" by installing everything from zero. I say "solved" because its been 4 hours and printing with no problem. Last time I couldnt print even for 10 minutes...
    before formating my computer I had installed Prusa drivers from the official website and a lot of drivers from other webs. And it worked for 2 days and then the problems started to show. Now its fixed i think (and I use USB from the back. Not anymore the USB in front the pc)
    Regards.
  • Do you know the chip used for communication?
    One thing you can do is using an old unused computer and install linux on it. Then install Repetier-Server to it to communicate with the printer. Host can communicate with server so you can still print using host. But communication will happen through linux with linux usb serial drivers. In case that is the problem with windows it would solve the communication problem. Plus you can stop host and print will continue as server will do the printing.
  • Found a thread that talked about to much power demand from heatbed and extruder caused issues... dropped bad temp from 60C to 50C and so far so good...for several days.. fingers crossed.
  • Newbie here. How do I RESET my printer? How do I SEND BUFFER BLOCK?
  • You don't. That is a misunderstanding of the message.
    If you get a timeout that means server did not see the "ok" from firmware that it received a command. Server buffers commands send and removes them internally when firmware says it was received. After the timeout server assumes a communication error on "ok" and resets this internal buffer and continues sending. So if the problem was just a communication error the print will then continue. Nothing to do here.
    Only if the problem is that the communication is blocked for some reason between printer and firmware you might test to deactivate and activate printer or shut down printer and unplug usb and reconnect again to get it running.
  • I'm having the same problem...just stops randomly mid print. No way to get it going again. Very Frustrating!!
    Windows server 2012 R2, Repetier 2.1.3, Tronxy X3A Marlin v. 1.0
