cura 4.0 and repetierServer pro 0.91.2 - cura: g-code flavor repetier : Firmware - Settings??
What I understand :
cura 4.0 has many options for the parameter: "g-code flavor" . RepetierServer : not
cura 4 e.g. has the Ultimaker 2 option RepetierServer : not
thats means it depends on the options which are set , if UM2+ printer works correctly
Which option/parameter did you choose for Cura and Repetier so that the result is the same like I'm just working with the SD card. ??
( maybe G-Code flavor marlin works better than RepRap if configured on Cura also on repetier)
the same file sliced with g-code "ulitmaker" and saved on SD card works fine no wraps around the nozzle
I will check the log
Does the log show any problems? I need more informations on what is happening to be possible to see where the problem might be.
