Printer speed controls
Not sure if this is going to make sense
I design (on Laptop) using RS design Spark mechnical
Export as STL file
Then use Cura (on Laptop) to slice & save GCode
I run Repetier Server on Raspberry Pi 3+
So I upload Gcode to that & then drive the printer from there
In Cura I can set Printer profile including speeds for top/bottom layers walls & infills
When I print there does NOT seem to be any speed variation
So I am assuming that the Printer settings in Repetier Server are overriding anything that comes from Cura
Is this correct
Can I do anything about this
You can check your code for F values (which are the speeds) and see if they differ over parts. Also check your firmware for maximum speed.
