No start signal detected - forcing start Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs communication timeout - reset send buffer block are all my errors that show up every few seconds i tried 230400 instead of 250000 and no change buffer size was already 127
Yes, no communication. All you see is what server sends but no response from firmware. So baud rate could also be 115200 or you have no firmware at all or you use wrong port or you have a monoprice board that needs different DTR/RTS settings (which you can currently only set in our Repetier-Server).
My computer is sending commands but the printer just keeps saying the same thing:
Communication timeout - reset send buffer block
