Migrated Pi To Dell PC running Ubuntu
in Linux
Ubuntu Keeps wanting me to do Updates now it wants me to upgrade to 16.04 will that mess up Repetier Server ?
running this install (http://download.repetier.com/files/server/debian-amd64/Repetier-Server-0.91.2-Linux.deb)
Pi image will not work on intel pc. Pi uses ARM processor and Intel intel code set, so the binary format is not compatible. What you can do is copy /var/lib/Repetier-Server to new pc to preserve all your data and settings.
Pi is just slow with lan/usb. For the different board is just important to have a debian like linux distro running on it. But you will face the same problem with the dell. There is no convenience image with webcam, network, usb mount so you have to configure these your self.
You can use the pi image a bit to help you get started. All these scripts are under /usr/local/Repetier-Setup - binaries in bin subfolder. So it is possible to extract the webcam stuff, but that is also described on our homepage.
ffmpeg can be downloaded on their homepage if it is not included in ubuntu. Alternatively just use avconv whcih is also supported.
