1.sensor defect error 2.printer runs into dry mode,
I have  disabled the heated bed and thermistor by using following changes in config.h file.
after thjat i am getting this error .Please give me solution
#define HAVE_HEATED_BED 0
#define HEATED_BED_MAX_TEMP 200
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 0
01:27:50.157 : Printer reset detected - initalizing
01:27:50.158 : start
01:27:50.170 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
01:27:51.435 : Free RAM:3763
01:27:51.441 : SelectExtruder:0
01:27:51.445 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
01:27:51.448 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
01:27:51.448 : PrinterMode:Laser
01:27:51.470 : X:0.00 Y:0.00 Z:0.000 E:0.0000
01:27:51.471 : DebugLevel:6
01:27:51.471 : SelectExtruder:0
01:27:51.473 : Begin file list
01:27:51.475 : End file list
01:27:51.484 : DebugLevel:6
01:27:51.485 : SelectExtruder:0
01:27:52.039 : DebugLevel:14
01:27:52.039 : Other:: temp sensor defect marked defect
01:27:52.043 : heated bed: temp sensor defect
01:27:52.044 : Error:Printer set into dry run mode until restart!
01:27:52.047 : Disabling all heaters due to detected sensor defect.
01:27:52.047 : DebugLevel:14
  • You see extruder reports > 1000°C which is also assumed to be a defect. If you don't have one and only a laser (seeing you are in laser mode) select the fake temperature sensor to the extruder. Otherwise check what is wrong - pin or wrong table or wrong sensor type.
