Server CPU temperature display
i don't know if i'm the only one with the problem, but i'm constantly dealing with a high cpu temperature of the raspberry. would it be possible to put the current cpu temperature of the pi in the upper status time? maybe also in the touch surface?
greeting Manuel
  • Normally temperature is no issue and therefor not important enough to show permanently. Maybe I add some outputs in a special screen some time, but not in main screen.
    Make sure to have good ventilation, that should normally suffice to have allowed temperatures.
