Unable to export large ZIP compilation of time-lapse
Hello everybody, first sorry for my bad English
I'm trying to export a zip folder of one of my time-lapse and nothing append. On a smaller time-lapse (Avg 1020 picture it takes time, but it's working). But on this project (1851 pictures) every time I try to export all pictures as zip it's looks like it's loading but after some time the message "waiting 192.168.1.7...." on the bottom of Firefox disappears and nothing append (like a timeout).
Does anyone encounter the same issue. There is an other solution to simply get this image or to move it on a USB drive?
ps : i'm using repetier server pro 0.91.0 on a raspberry pi 3
Nico.
You can also run top when doing that to see if server memory usage increases, but i think the library for zipping does not hold it in memory so size should be no problem.
Over ssh you can just copy the files. They are all in /var/lib/Repetier-Server/printer/<slug>/timelapse folder.
