Printer Configuration Wizard
With new Repetier-Server Pro v. 0.91 it is not possible to add new printer via wizard. Everything goes well up to step 5, but then it is not possible to "finish" it. Button just doesn't do anything and you can not save new configuration. Some problems with extruder I guess, because extruder offset's are not fetched from eeprom.
  • Well, maybe there was some communication problem between Arduino and Raspberry. After reboot I manage to set extruder and save data. I did not try configuration wizard again...
