Low free space - OrangePi
I succesfully installed on my OrangePi and it is running fine, however server says it has only 30Mb of free space. I am using a 32Gb SD card and did the partition resize, which says it is already at maximum size. There are two partitions on the disc, one is FAT32 at 64Mb and other one is Linux and is 28.9Gb.
Where is the problem and how can I tell the server to look for the bigger partition?
  • Data is stored in /var/lib/Repetier-Server and the volume containing that must be big. You can move it to an empty big folder and add a link there pointing to your decided position.
