RH crashes during print after today's Ubuntu updates to Mono
Ubuntu 14.04 pushed a software update this evening and now prints crash about 2 minutes into the print, with the following not terribly useful looking output:
"Rebuild object False
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
at System.Threading.EventWaitHandle.Reset () [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Threading.EventWaitHandle:Reset ()
at System.Threading.Timer+Scheduler.SchedulerThread () [0x00000] in <filename unknown>:0
at System.Threading.Thread.StartInternal () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
at System.Threading.Thread.StartInternal () [0x00000] in <filename unknown>:0"
Not sure which mono packages to pull the version information from, so I went with mono-runtime, but it appeared that basically all the Mono packages got updated.
dpkg -s mono-runtime
Package: mono-runtime
Status: install ok installed
Priority: optional
Section: cli-mono
Installed-Size: 93
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Source: mono
Version: 3.2.8+dfsg-4ubuntu1.1
RH 1.0.6, slicing with Cura.
Priority: optional
Section: cli-mono
Installed-Size: 93
Architecture: amd64
Source: mono
Unfortunately that was all the output that appeared in shell. Is there a way to run it with more verbose output?
Not sure if this is related, but I realized when launched from the shell it reports an error even if I don't do anything. Literally, run it from the shell, and click the close button brings up this:
"Unhandled Exception:
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
at System.Drawing.Graphics.GdipMeasureString (IntPtr graphics, System.String text, System.Drawing.Font font, System.Drawing.RectangleF& layoutRect, IntPtr stringFormat) [0x00000] in <filename unknown>:0
at System.Drawing.Graphics.MeasureString (System.String text, System.Drawing.Font font, Int32 width, System.Drawing.StringFormat format) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:MeasureString (string,System.Drawing.Font,int,System.Drawing.StringFormat)
at System.Windows.Forms.TextRenderer.MeasureTextInternal (IDeviceContext dc, System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags, Boolean useMeasureString) [0x00000] in <filename unknown>:0
at System.Windows.Forms.TextRenderer.MeasureText (System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripItem.OnParentChanged (System.Windows.Forms.ToolStrip oldParent, System.Windows.Forms.ToolStrip newParent) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripItem.set_Parent (System.Windows.Forms.ToolStrip value) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:set_Parent (System.Windows.Forms.ToolStrip)
at System.Windows.Forms.ToolStripItemCollection.Remove (System.Windows.Forms.ToolStripItem value) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripDropDownItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripMenuItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
at System.ComponentModel.Component.Finalize () [0x00000] in <filename unknown>:0 "
Just in case that helps.
