Timelapse with EDIMAX IC-5150 not working
I am getting a bit desperate. I am trying to use the timelapse feature but no success.
I am using EDIMAX IC-5150 under Linux Mint.
I configured the camera, I see dynamic and static input from camera in Repetier Server environment.
I also set the rules for interval of taking the pictures needed for timelapse generating.
FFMPEG is installed.
When I start printing the server indicates that it is recording.
After finishing the job there are no stills saved in the directory and therefore generating of the timelapse fails.
Mjpg_streamer is not installed, because this cam supports direct JPG and MJPEG output.In my opinion it is not needed in this case or am I wrong? Honestly,I have no idea what else to check....
Could you help me,please?
Thank you in advance for any help.
Best regards
Martin
Best regards
Martin
If that works timelapse will store pictures. So even without ffmpeg you would at least see the pictures. With ffmpeg it will get converted into a mp4 video.
Everything was okay and preview of static and dynamic worked also, but timelapse was not working.
I did some more research and found out that the problem is that I am using the password protected access.
The link to my static source seems like this:
http://user:password@192.168.1.20/snapshot.jpg?user=user&pwd=password
In this case Repetier shows the preview but does not generate any timelapse, because it does not have any captured stills.
I decided to activate the anonymous access for testing purposes and....BINGO...the timelapse started to work.
So...the resume seems to be, that Repetier has some problem when using password protected access to the camera.
I also tried to search something in the Repetier manual, if there is something meant about NOT using the password protected access and found nothing.So,I suspect,that it is a bug.The strange thing is,that in settings I see the preview, but no stills are captured when using NON-anonymous access.
I don think that using anonymous access is the solution, it is just workaround, because it would be very useful to use the password protected access.
Please, let me know your opinion.
Best regards
Martin
Your examples has it double - the problem is only with the user:password@ variant so you can try if the other one alone works (?user=use&pwd=password). My IP webcam supports both.
To your note about the syntax for this camera (doubled usr/pass) - unfortunately the format is correct.
For this type it really should be doubled like in this example.
No other variants are accepted and if there is only part of this code, then manual entering usr/pass is required.
I tried these variants with no success...
http://user:password@192.168.1.20/snapshot.jpg - NOT ACCEPTED
http://192.168.1.20/snapshot.jpg?user=user&pwd=password - NOT ACCEPTED
Any other ideas?
Best regards
Martin
P.S. The syntax generator for cameras is available here:
For EDIMAX brand - https://www.ispyconnect.com/man.aspx?n=Edimax#
The other brands - https://www.ispyconnect.com/sources.aspx
Very useful resource for the research...
Link is really good if I someone does not know the link.
