WI-Fi problem
Hello
I'm having problems with the last repetier server firmware setup. I already have Repetier Server Pro installed with the 4.9.35-V7+ (as said on my Raspberry) and it works really great.
I just wanted to test the last version but I'm unable to conect to my Raspberry through Putty as I do with the 4.9.35-V7+ version.
When I try to boot with a HDMI screen, I see that if fails to connect and says that I son't have internet access.
What can I do ? My friend has the identical problem.
Thanks for your support
Franck
Franck
Can you describe what you did to connect, so I can follow or even replay the problem.
Could I manually enter informations in the repetier.xml file ?
Franck
https://www.repetier-server.com/knowledgebase/wlan-configuration-on-sd-card/
You can also connect with ethernet to get ssh access and configure it in normal web interface and once wifi is working remove ethernet.
What pi do you have? Do you have one with integrated wifi or do you use a wifi stick. In the latter case check with iwconfig if linux sees the wifi component.
I don't understand how to access to the console since Repetier Server firmware boots to the license registration page ... Usually I use Putty to access.
If you connect ethernet you are also connected over that interface and can login there using putty.
In the license screen you can also switch to wifi setup. I assume you tried this already?
Do you see your network there? Requires visible SSID.
If you have one of the non HDMI displays you always need to install video drivers according to vendor instructions.
I have a Raspberry Pi 3 B+ with a power supply (Rasppberry 2.5 amp)
The default is that gui appears on hdmi screen. If you have one it should work otherwise you might need to install drivers and change some files.
For wifi - did you set your region right? The default region does not have channels 12/13 I think it was, while e.g. in Germany they are allowed. So if your wifi uses one of these they are only working after setting right region.
Yes I set the right region. I have a 3.5'' screen and I hav to download drivers to make it work. I'll check the autologin but I don't remember if I saw it ...
Where can I find older versions other than 0.86 ?
is our download page.
With 3.5" displays it is quite normal that only console appears. You need to configure x server to show on the display. By default it shows xserver to HDMI output. See your vendor instructions or check forum. Lately someone described it for waveshare displays I think.
