Repetier Server on Raspberry Pi 1 with Edimax Wifi Stick
ia am trying to use the Server on an Raspberry Pi 1 with an Edimax Wifi Stick.
In the Settings Menu is under Wifi only the message "This installation does not support Wifi configuration" or sometimes there is just the message that no Wlan Adapter installed.
By typing lsusb i get this result:
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
By typing dmesg i get this for about 200 times:
[  551.945773] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Can anyone tell me what to do???
best regards
Iksi
  • iwconfig
    should show the state. I have one stick that works not well with our solution a sit can not scan networks and have one connection. Not sure whcih type that was. Aynhow, better first check if linux has it working or not and then see what is wrong.
  • I have installed Raspbian Lite and configured the Wlan, no Problems
    Afterwards i have installed Repetier Server, now it works without Problems, but i can't set it up in Repetier, but this is okay for me....
    Thanks for your Help
