BLTouch commands
 Is there a list for the commands to use for BLTouch in repetier firmware? I have searched all over the net and have found several lists of commands but when I try them in Repeteier Host none work, i get unknown command message....
  • Mainly M340 to set servo position which controls the pin and behaviour. Then you just need to go up fast enough so the bltouch does not go into error mode when pin is released again.
    There are several solution alone in this forum that describe the settings they use.
