System.OutOfMemoryException: array dimensions exceeded supported range error
Slicing a very large file, 10 ft by 10 ft. Getting this error, cannot slice. How may I go about fixing this? The file will slice for 25 minutes, get almost to the end, then give me the error. Thanks in advance.
~Drew
~Drew
In that case you can set filament quality to simple instead of medium and that reduces memory usage by factor 10 or so. Gcode is then rendered as lines (ugly) but at least you can load it into memory.
For printing I advice to use repetier-server as it does not care about size. It was written to handle files bigger then ram without much memory usage. Host will slow down during print and use more and more memory.
~Drew
Press Alt+F and you see in the status bar the FPS value indicating how fast display updates are. You can do this in preview tab then you know the speed when print is finished.
