Repetier Host & Slic3r settings for BIBO 2 touch printer
I'm searching for the correct Repetier host printer settings (several tabs, printer, extruder, printer type and so on) for BIBO 2 touch
I also search for the settings of Slic3r for the bibo
  • Could it be that the Bibo does not have a large fan community and is not very common, that it is an unknown exotic among 3D printers? I thought I'd get a lot of answers here, that's too bad.
  • Actually I never heard that name before:-( It is surely not a wide spread printer as Prusa or A8. But using the wizard it is not so hard to get a working configuration for slicing. Default values are good to start with and then you adjust as you see problems in the print.
