Help: my Z axis can't stop moving down
edited December 2018 in Repetier-Host
I have tested everything and it homes perfectly. I have tested everything and it homes perfectly. However, whenever I press Z- or send g code commands like G1 Z10 F1000, it won't stop coming down. It just keep moving downward until I hit Emergency stop button and i press z+ button then it moves perfect. How do I solve this?
Every help has a great meaning to me!
  • edited December 2018
    what about some complete informations?
    what printer type, which Firmware , what homing direction, which Electronic Hardware,where are endstops etc.etc.etc
    With your description nobody can help you
  • Oh, sorry! My printer is delta type. I use repetier fw, arduino mega and ramp 1.4. All my endstop at max position
  • After homing check position with M114. My guess is that z length is much too high so z=0 is below bed level. Start with G1 Zxxx where xxx is some mm lower then what M114 returned.
      Repetier said:
      After homing check position with M114. My guess is that z length is much too high so z=0 is below bed level. Start with G1 Zxxx where xxx is some mm lower tAfter following your suggestions. I was able to fix it. Thank you very much
