loading files from usb directly to raspberry pi
Hello, hopefully I posted this in the right spot
Is there any way to upload g-code files from a usb connected directly to the raspberry pi? I am very new to coding, and the Raspberry Pi, and can't seem to figure out how. I have a Printrbot Simple Metal. Everything works, I can upload g-code through the internet, and my Printrbot will print. I can move the Printrbot manually, heat everything up, etc. and it all works fine, but sometimes I do not have internet connection, and would like to just insert a usb, and let it rip. Any advice helps. I have the latest version of repetier on the Pi as well, and I use Cura to post G-code.
I also tried this with putty, but it didn't seem to help:
https://unix.stackexchange.com/questions/330094/udev-rule-to-mount-disk-does-not-work
I've been searching for a couple of days, and haven't gotten anywhere.
