Repetier Host Freezing on startup
I've run RH on this PC before but after a hardware update it seems to freeze up every few dozen launches.
Thankfully I am also using octoprint so it doesn't matter in the printing process. However, I pretty much only use RH for slicing and printer management so it's quite annoying when I have to do a clean reinstall every single time. Keeping the settings results in a lock upon next launch, so could it be corrupting itself?
Running 2.1.3 on Win 10
