ENDSTOP CODES FOR DELTA TYPE 3D PRİNTER
Hello ı have delta type 3d printer and ı am usıng repetier firmware. But my endstops don't working. And motors don't moving. I am sending my endstops codes. Can you give me an advices for this problem.
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_Z_BACK_ON_HOME 1
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
should be the other way around. Also I'd increase
to 20mm.
At the top you can not print anyway as radius is 0 in reality or you hit a endstop. So to allow some bed leveling without voiding the top position after homing just increase it.
