Manual control but no prints
Been using Repetier server connected to my homemade I3 for a while. Printed fine yesterday. Today I can control my bed and nozzle temps manually from the server but it will no longer start to heat when I transfer a job or try to print directly from the server.
Said another way, repetier server controls the printer fine using the manual controls but I can no longer start a print from it.
Any ideas?
Any ideas?
Nope. Nothing in the queue. I restarted the system repetier is on and the printer several times and no luck. I thought maybe heated bed got turned off but no, it is still set correctly.
Manual control from repetier but no prints start.
I see the temps both toggle around 20.5 degrees plus or minus a couple of degrees.
If I manually input a setpoint for the bed or the nozzle from repetier server, they turn red and go up to those temps and toggle around whatever setpoint I gave em plus or minus a degree or two.
This all worked fine for probably 2 months until 2 days ago.
I get this on all files now including files i printed just days ago.
I copy the commands out of this file and enter them directly into the console and the heat numbers go red and it heats as it should.
Something is really messed up.
Reinstalled the .86 version and no luck.
Uninstalled and decided to go back to octoprint but then changed my mind and decided to try one more time with the .86 version and now it is working again.
I did no updates between the 2 months it worked and the day it quit. I did a ton of updates and reinstalls and it still didn't work.
I don't mind going round and round with something as long as I learn so I can fis it next time but I have no idea what happened.
That is not a gcode file, taht is a stl file in ascii format! Sending this does nothing to the printer, that is correct.
That is a gcode which you can send.
So as it looks you are uploading the wrong files which make it not work. Upload gcode and not stl and it should work again.
I got those errors when i sent a print from Cura. Direct printing that exact gcode file failed, no heat and no motion. Sending these commands from repetier host console worked.
After the reload it all works as it always did.
After the new install of .90 it is working again.
Normally would not be screwing around with the printer on thanksgiving morning but my wife wants a couple of ornaments for the tree decorating later today. She and the kids are cooking Thanksgiving lunch and all I have to do is "get those ornaments printed". Good deal for me.
Reinstalling or uninstalling and installing is effectly the same. You just refesh the files with the same copy. However it can make a difference if the sd card is bad. Lately I had the same problem. Suddenly some folders stopped working or content disappeared/files changed. If you do some stuff changing file system you might trick it into a working area but that can change any time. Try a different card (maybe even different type) with new image instead. Then you will see if it is more stable again. Did the same and now same pi is working stable for now.
