Can't open mys stl file in RH directly
I use Linux Mint19. When I double clic on a stl file in my file manager, RH opens but the file is not opened in. When RH is launched manually and I open my file, all's good.
What I can do to solve this issue ?
  • I don't think the parameter gets through which is why host does not see it. SO there is nothing you can do.
    Thank you for answer.  All was working good in older versions. That's why I'm surprised.
  • Did you switch to appimage? appimage has many redirections as now the appimage scripts get started which will then call the host. The tgz version has not changed as far as I know but is much harder to set up.
  • I use Appimage as suggested (and it is more easy, you're right ;) . Maybe try tgz...
  • That was the problem. I installed tgz version and deleted Appimage and all works good. Thank you for help.
  • Ok, for next image I will check if I can forward the parameters.
  • Thank you for the future... ;)
